* Per PR233, moved librpc to exec. Ralf will patch after move.
The patches associated with this PR are out of date.
* configure.ac, wrapup/Makefile.am: Modified.
* librpc, librpc/ChangeLog: Removed.
./include/rpc/.cvsignore, ./include/rpc/Makefile.am,
./include/rpc/auth.h, ./include/rpc/auth_des.h,
./include/rpc/auth_unix.h, ./include/rpc/clnt.h,
./include/rpc/des.h, ./include/rpc/des_crypt.h,
./include/rpc/pmap_clnt.h, ./include/rpc/pmap_prot.h,
./include/rpc/pmap_rmt.h, ./include/rpc/rpc.h,
./include/rpc/rpc_com.h, ./include/rpc/rpc_msg.h,
./include/rpc/svc.h, ./include/rpc/svc_auth.h,
./include/rpc/types.h, ./include/rpc/xdr.h,
./include/.cvsignore, ./include/Makefile.am,
./include/rpcsvc/.cvsignore, ./include/rpcsvc/Makefile.am,
./include/rpcsvc/bootparam_prot.x, ./include/rpcsvc/crypt.x,
./include/rpcsvc/key_prot.x, ./include/rpcsvc/klm_prot.x,
./include/rpcsvc/mount.x, ./include/rpcsvc/nfs_prot.x,
./include/rpcsvc/nis.x, ./include/rpcsvc/nis_cache.x,
./include/rpcsvc/nis_callback.x, ./include/rpcsvc/nis_db.h,
./include/rpcsvc/nis_object.x, ./include/rpcsvc/nis_tags.h,
./include/rpcsvc/nislib.h, ./include/rpcsvc/nlm_prot.x,
./include/rpcsvc/pmap_prot.x, ./include/rpcsvc/rex.x,
./include/rpcsvc/rnusers.x, ./include/rpcsvc/rquota.x,
./include/rpcsvc/rstat.x, ./include/rpcsvc/rwall.x,
./include/rpcsvc/sm_inter.x, ./include/rpcsvc/spray.x,
./include/rpcsvc/yp.x, ./include/rpcsvc/yp_prot.h,
./include/rpcsvc/ypclnt.h, ./include/rpcsvc/yppasswd.x,
./include/rpcsvc/ypupdate_prot.x, ./include/rpcsvc/ypxfrd.x,
./.cvsignore, ./Makefile.am, ./README_RTEMS,
./configure.ac, ./src/rpc/PSD.doc/.cvsignore,
./src/rpc/PSD.doc/Makefile.am, ./src/rpc/PSD.doc/nfs.rfc.ms,
./src/rpc/PSD.doc/rpc.prog.ms, ./src/rpc/PSD.doc/rpc.rfc.ms,
./src/rpc/PSD.doc/rpcgen.ms, ./src/rpc/PSD.doc/xdr.nts.ms,
./src/rpc/PSD.doc/xdr.rfc.ms, ./src/rpc/.cvsignore,
./src/rpc/DISCLAIMER, ./src/rpc/Makefile.am,
./src/rpc/README, ./src/rpc/auth_des.c,
./src/rpc/auth_none.c, ./src/rpc/auth_time.c,
./src/rpc/auth_unix.c, ./src/rpc/authdes_prot.c,
./src/rpc/authunix_prot.c, ./src/rpc/bindresvport.3,
./src/rpc/bindresvport.c, ./src/rpc/clnt_generic.c,
./src/rpc/clnt_perror.c, ./src/rpc/clnt_raw.c,
./src/rpc/clnt_simple.c, ./src/rpc/clnt_tcp.c,
./src/rpc/clnt_udp.c, ./src/rpc/clnt_unix.c,
./src/rpc/crypt_client.c, ./src/rpc/des_crypt.3,
./src/rpc/des_crypt.c, ./src/rpc/des_soft.c,
./src/rpc/get_myaddress.c, ./src/rpc/getpublickey.c,
./src/rpc/getrpcent.3, ./src/rpc/getrpcent.c,
./src/rpc/getrpcport.3, ./src/rpc/getrpcport.c,
./src/rpc/key_call.c, ./src/rpc/key_prot_xdr.c,
./src/rpc/netname.c, ./src/rpc/netnamer.c,
./src/rpc/pmap_clnt.c, ./src/rpc/pmap_getmaps.c,
./src/rpc/pmap_getport.c, ./src/rpc/pmap_prot.c,
./src/rpc/pmap_prot2.c, ./src/rpc/pmap_rmt.c,
./src/rpc/publickey.3, ./src/rpc/publickey.5,
./src/rpc/rpc.3, ./src/rpc/rpc.5, ./src/rpc/rpc_callmsg.c,
./src/rpc/rpc_commondata.c, ./src/rpc/rpc_dtablesize.c,
./src/rpc/rpc_prot.c, ./src/rpc/rpc_secure.3,
./src/rpc/rpcdname.c, ./src/rpc/rstat.1,
./src/rpc/rstat_svc.8, ./src/rpc/rtems_portmapper.c,
./src/rpc/rtems_rpc.c, ./src/rpc/rtime.3, ./src/rpc/rtime.c,
./src/rpc/svc.c, ./src/rpc/svc_auth.c,
./src/rpc/svc_auth_des.c, ./src/rpc/svc_auth_unix.c,
./src/rpc/svc_raw.c, ./src/rpc/svc_run.c,
./src/rpc/svc_simple.c, ./src/rpc/svc_tcp.c,
./src/rpc/svc_udp.c, ./src/rpc/svc_unix.c,
./src/xdr/.cvsignore, ./src/xdr/Makefile.am, ./src/xdr/xdr.3,
./src/xdr/xdr.c, ./src/xdr/xdr_array.c,
./src/xdr/xdr_float.c, ./src/xdr/xdr_mem.c,
./src/xdr/xdr_rec.c, ./src/xdr/xdr_reference.c,
./src/xdr/xdr_sizeof.c, ./src/xdr/xdr_stdio.c,
./src/.cvsignore, ./src/Makefile.am: Moved to exec.
* include/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/rpcsvc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/PSD.doc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/rpc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/xdr/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* include/rpc/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/rpc/Makefile.am: Apply include_*HEADERS instead of
H_FILES.
effects in RTEMS source code.
* src/rpc/Makefile.am, src/rpc/auth_time.c, src/rpc/clnt_simple.c,
src/rpc/clnt_tcp.c, src/rpc/clnt_udp.c, src/rpc/clnt_unix.c,
src/rpc/get_myaddress.c, src/rpc/pmap_clnt.c, src/rpc/pmap_getmaps.c,
src/rpc/pmap_getport.c, src/rpc/pmap_rmt.c, src/rpc/rtime.c,
src/rpc/svc_tcp.c, src/rpc/svc_udp.c, src/rpc/svc_unix.c:
Use of _read, _write, and _close as macros conflicted with
newlib's use of these as routine names. They were renamed to
include "_RPC_" prefix.
* src/xdr/xdr_float.c: Added A29K support.
* src/rpc/Makefile.am, src/xdr/Makefile.am: Include compile.am
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
generated assembly from it.
that contains:
* Removes MKLIB
handling)
converted to automake.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
<corsepiu@faw.uni-ulm.de>.
in the previous commits.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
mkdir c/src/librpc
mkdir c/src/librpc/src
mkdir c/src/librpc/include
rm -rf c/src/lib/librpc
rm -rf c/src/lib/include/rpc
in the required order .
# make[5]: Entering directory
# mips64orion-rtems-gcc -v
# mips64orion-rtems-ld -v
mkdir c/src/librpc
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
Hello,
host :
- one for RTEMS it self,
- one for GDB-4.17.
1/ RTEMS patch
This patch adds 2 libraries :
- the Remote Debugger library
--enable-rdbg
rtems_rdbg_initialize ();
2/ GDB-4.17 patch
To connect to a target, use :
And... Debug ;)
