path: root/c/src/librdbg/include/rdbg/i386/rdbg_f.h (follow)
* 2007-08-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-08-021-39/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac, wrapup/Makefile.am: Remove RDBG. * aclocal/check-rdbg.m4, aclocal/enable-rdbg.m4, librdbg/.cvsignore, librdbg/Makefile.am, librdbg/preinstall.am, librdbg/include/rdbg/rdbg.h, librdbg/include/rdbg/servrpc.h, librdbg/include/rdbg/i386/rdbg_f.h, librdbg/include/rdbg/i386/reg.h, librdbg/include/rdbg/m68k/rdbg_f.h, librdbg/include/rdbg/m68k/reg.h, librdbg/include/rdbg/powerpc/rdbg_f.h, librdbg/include/rdbg/powerpc/reg.h, librdbg/src/_servtgt.c, librdbg/src/awk.svc, librdbg/src/excep.c, librdbg/src/ptrace.c, librdbg/src/rdbg.c, librdbg/src/remdeb.x, librdbg/src/servbkpt.c, librdbg/src/servcon.c, librdbg/src/servrpc.c, librdbg/src/servtgt.c, librdbg/src/servtsp.c, librdbg/src/servutil.c, librdbg/src/i386/excep_f.c, librdbg/src/i386/rdbg_cpu_asm.S, librdbg/src/i386/rdbg_f.c, librdbg/src/i386/any/remdeb.h, librdbg/src/i386/any/remdeb_f.x, librdbg/src/i386/any/remdeb_svc.c, librdbg/src/i386/any/remdeb_xdr.c, librdbg/src/m68k/excep_f.c, librdbg/src/m68k/rdbg_cpu_asm.S, librdbg/src/m68k/rdbg_f.c, librdbg/src/m68k/any/remdeb.h, librdbg/src/m68k/any/remdeb_f.x, librdbg/src/m68k/any/remdeb_svc.c, librdbg/src/m68k/any/remdeb_xdr.c, librdbg/src/powerpc/excep_f.c, librdbg/src/powerpc/rdbg_cpu_asm.S, librdbg/src/powerpc/rdbg_f.c, librdbg/src/powerpc/new_exception_processing/remdeb.h, librdbg/src/powerpc/new_exception_processing/remdeb_f.x, librdbg/src/powerpc/new_exception_processing/remdeb_svc.c, librdbg/src/powerpc/new_exception_processing/remdeb_xdr.c: Removed.
* Remove stray white spaces.Ralf Corsepius2004-04-151-3/+0
* * So many patches have been posted recently on the mailing list andJoel Sherrill2002-02-011-0/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | because we were unable to find correct solution to compile on various linux distros (due to rpcgen incompatibilities), and because the coding style of rdbg was rather inconsistant among various pieces of code, I decided to: 1) make some cleaning regarding global coding style (using indent + manual edits), 2) incorporate/review the paches send by various people (S. Holford, T. Strauman), 3) Fix the bug due to varying rpcgen code generation in remdeb_svc.c, 4) Remove some dead code, 5) Apply a patches enabling to call enterRdbg imediately after rdbg initialization is done, NB : the paches is huge but it is mainly due to coding styke chnages. Only few lines of codes have been really changed and they do not impact rdbg functionnality (AFAIKT). * include/rdbg/servrpc.h, include/rdbg/i386/rdbg_f.h, include/rdbg/m68k/rdbg_f.h, include/rdbg/powerpc/rdbg_f.h, src/_servtgt.c, src/awk.svc, src/excep.c, src/ptrace.c, src/rdbg.c, src/remdeb.x, src/servbkpt.c, src/servcon.c, src/servrpc.c, src/servtgt.c, src/servtsp.c, src/servutil.c, src/i386/excep_f.c, src/i386/rdbg_f.c, src/i386/any/Makefile.am, src/i386/any/remdeb.h, src/i386/any/remdeb_svc.c, src/i386/any/remdeb_xdr.c, src/m68k/excep_f.c, src/m68k/rdbg_f.c, src/m68k/any/Makefile.am, src/m68k/any/remdeb.h, src/m68k/any/remdeb_svc.c, src/m68k/any/remdeb_xdr.c, src/powerpc/excep_f.c, src/powerpc/rdbg_f.c, src/powerpc/new_exception_processing/Makefile.am, src/powerpc/new_exception_processing/remdeb.h, src/powerpc/new_exception_processing/remdeb_svc.c, src/powerpc/new_exception_processing/remdeb_xdr.c: Modified.
* Patch from Eric Valette <valette@crf.canon.fr> and Emmanuel RaguetJoel Sherrill1999-08-101-29/+17
| | | | | | | | | | | | <raguet@crf.canon.fr>: - the dec21140 driver code has been hardened (various bug fixed) Emmanuel, - bug in the mcp750 init code have been fixed (interrupt stack/initial stack initialization), BSS correctly cleared (Eric V) - remote debugging over TCP/IP is nearly complete (berakpoints, backtrace, variables,...) (Eric V), - exception handling code has also been improved in order to fully support RDBG requirements (Eric V),
* Patch from Emmanuel Raguet <raguet@crf.canon.fr> to add remote debug serverJoel Sherrill1998-12-031-0/+53
and RPC support to RTEMS. Thanks. :) Email follows: Hello, For Xmas, here is the Remote Debugger on RTEMS ! Here are 2 patches for the Remote Debugger on RTEMS for pc386 from Linux host : - one for RTEMS it self, - one for GDB-4.17. 1/ RTEMS patch -------------- This patch adds 2 libraries : - a simplified SUN RPC library - the Remote Debugger library The configuration command is the following : ../rtems4/configure --target=i386-rtemself --enable-rtemsbsp=pc386 --enable-rdbg The SUN RPC library is built only if networking is set. The RDBG library is built if networking and enable-rdbg are set. The function used to initialize the debugger is : rtems_rdbg_initialize (); A special function has been created to force a task to be in a "debug" state : enterRdbg(). The use of this function is not mandatory. 2/ GDB-4.17 patch ----------------- This patch create a new RTEMS target for GDB-4.17. The configuration command is the following : ./configure --enable-shared --target=i386RTEMS To connect to a target, use : target rtems [your_site_address] Then, attach the target using : attach 1 And... Debug ;) You can obtain the original GDB-4.17 on ftp://ftp.debian.org/debian/dists/stable/main/source/devel/gdb_4.17.orig.tar.gz This has been tested from a Debian 2.0.1 linux host.
