Move networking libraries to c/src/exec/libnetworking
* configure.ac: Reflect Moval.
* Makefile.am: Reflect Moval.
* wrapup/Makefile.am: Reflect Moval.
* nfs/bootp_subr.c, rtems/rtems_bootp.c, rtems/rtems_bsdnet.h,
rtems/rtems_bsdnet_internal.h Added support for populating the
initial "root" filesystem with information obtained via the DHCP
response.
effects in RTEMS source code.
* machine/types.h: Added _CLOCKID_T_ and _TIMER_T_ to be in sync
with newlib's <machine/types.h>.
* rtems/rtems_bsdnet_internal.h: newlib now includes definition
of struct itimerval in <sys/time.h>.
* machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h,
rtems_webserver/webmain.c: machine/types.h should not have
included rtems.h. It is now including precisely the
least amount of low level, yet portable .h files to get
the basic RTEMS types defined. This rippled into other
files since rtems_bsdnet_internal.h used machine/types.h to include
rtems.h.
porting of ACE to RTEMS.
network interface names. This change does not introduce any
compatibility problems.
so that the libc code did not have to know about (struct socket).
RTEMS permits using the SO_SNDTIMEO and SO_RCVTIMEO socket options to
set a timeout for most socket I/O operations. However, in RTEMS
4.0.0, those options do not affect connect or accept. I don't know of
any way to put a timeout on those calls in RTEMS 4.0.0; can anybody
point to one.
Since it is frequently useful to have a timeout on accept, and
sometimes useful to have a timeout on connect shorter than the BSD
system default of 75 seconds, the following patch causes SO_RCVTIMEO
to affect connect and accept.
in include file order.
