* libnetworking/pppd/Makefile.am: Use preinstall.am.
PR 750/networking
* libnetworking/pppd/sys-rtems.c: Avoid NULL dereference in
wait_input().
* libnetworking/pppd/Makefile.am: CPPFLAGS += -D__BSD_VISIBLE.
PR 755/rtems
* libnetworking/pppd/ipcp.c: Include <rtems/bsdnet/servers.h>.
Remove local declarations of rtems_bsdnet_nameservers,
rtems_bsdnet_nameservers_count.
PR 771/pppd
* libnetworking/pppd/chat.c, libnetworking/pppd/rtemsmain.c: The fix
committed to fix PR736 breaks pppd. chat.c should have its own static
ttyfd for pppd to work correctly. The symptom is that second
invokation of chat (for connect script) fails due to pppd_ttyfd set
to -1 by previous chat invokation (for init script). In addition,
this patch fixes leaving of dangling pointer in the abort_stbring[]
by chat_send().
PR 736/pppd
* libnetworking/pppd/chat.c, libnetworking/pppd/demand.c,
libnetworking/pppd/pppd.h, libnetworking/pppd/rtemsmain.c,
libnetworking/pppd/sys-rtems.c, libnetworking/pppd/utils.c: ttyfd
should not be static and should have a name more specific to pppd.
* libchip/Makefile.am, libnetworking/pppd/Makefile.am,
libnetworking/rtems_servers/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am,
librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* libnetworking/pppd/Makefile.am,
libnetworking/rtems_telnetd/Makefile.am:
Remove build-variant support.
* libnetworking/pppd/rtemspppd.c: rtems_task_priority priority.
* libnetworking/rtems_telnetd/telnetd.c: Eliminate rtems_unsigned32.
* aclocal/rtems-cpu-subdirs.m4, libchip/shmdr/shm_driver.h,
libnetworking/pppd/utils.c: i960 obsoleted and all references
removed.
PR 599/pppd
* libnetworking/pppd/chat.c: Fre memory that is allocated to fix leak.
libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am,
support/Makefile.am: Don't include lib.am.
* libnetworking/rtems_webserver/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_telnetd/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/rtems_servers/Makefile.am: Add PREINSTALL_DIRS.
* libnetworking/pppd/Makefile.am: Add PREINSTALL_DIRS.
* Makefile.am: Remove wrapup.
* pppd/Makefile.am: Build libpppd.
Use automake-compilation rules.
* rtems_servers/Makefile.am: Build libftpd.
* rtems_telnetd/Makefile.am: Build libtelnetd.
* rtems_webserver/Makefile.am: Build libhttpd.
* wrapup/Makefile.am: Remove (Unused).
* pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Ditto.
* rtems_telnetd/Makefile.am: Ditto.
* rtems_webserver/Makefile.am: Ditto.
* pppd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_servers/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_telnetd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* rtems_webserver/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Cosmetics.
* pppd/Makefile.am: Cosmetics.
* pppd/Makefile.am: Remove all-local: $(ARCH).
* rtems_servers/Makefile.am: Remove all-local: $(ARCH).
* rtems_telnetd/Makefile.am: Remove all-local: $(ARCH).
* rtems_webserver/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Apply dirstamps to preinstallation.
* pppd/Makefile.am: Ditto.
* wrapup/Makefile.am: Ditto.
pppd/Makefile.am: Reflect having moved automake.
rtems_servers/Makefile.am: Reflect having moved automake.
rtems_telnetd/Makefile.am: Reflect having moved automake.
rtems_webserver/Makefile.am: Reflect having moved automake.
* configure.ac: Remove (Merged into ../configure.ac).
* .cvsignore, Makefile.am, pppd/Makefile.am,
rtems_servers/Makefile.am, rtems_telnetd/Makefile.am,
rtems_webserver/Makefile.am, wrapup/Makefile.am:
Reflect having merged configure.ac into ../configure.ac
* pppd/chat.c: Removed warnings.
* pppd/fsm.c: Make peer_mru global again.
* pppd/magic.c: Remove *rand48.
* pppd/chap.c: Remove prototypes of *rand48.
PR 371/pppd
* pppd/auth.c, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/lcp.c,
pppd/options.c, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c:
Change many symbols to static. There are still global symbols in
rtemspppd.h which might need to be changed or converted into member
of a structure which is dereferenced with a pointer that is managed
as a per task variable. But this patch should avoid many conflicts.
* pppd/chat.c: Convert routines with common names to static. This
included get_char(), put_char(), and character() among others.
* pppd/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* pppd/auth.c, rtems_webserver/uemf.h: Removed warnings.
* pppd/ipcp.c, rtems_servers/ftpd.c: Add include files to resolve
warnings.
* rtems_servers/ftpd.c: Remove unused variable buf.
* pppd/md5.c: #include <string.h> to make gcc31 happy.
* rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy.
* rtems_webserver/webmain.c: Remove unused variable dir, cp.
* pppd/utils.c: Include i960 in varargs conditional to avoid error.
* pppd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_servers/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_telnetd/Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems_webserver/Makefile.am: Use .$(OBJEXT) instead of .o.
* pppd/chap.c, pppd/fsm.c, pppd/fsm.h, pppd/upap.c: Per PR255
fix prototype mismatches.
* pppd/utils.c: Adapt to gcc-3.x.
* arpa/Makefile.am: Remove AUTOMAKE_OPTIONS.
* kern/Makefile.am: Remove AUTOMAKE_OPTIONS.
* lib/Makefile.am: Remove AUTOMAKE_OPTIONS.
* libc/Makefile.am: Remove AUTOMAKE_OPTIONS.
* machine/Makefile.am: Remove AUTOMAKE_OPTIONS.
* net/Makefile.am: Remove AUTOMAKE_OPTIONS.
* netinet/Makefile.am: Remove AUTOMAKE_OPTIONS.
* nfs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* pppd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sys/Makefile.am: Remove AUTOMAKE_OPTIONS.
* vm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* net/if_ppp.c, pppd/auth.c, pppd/chat.c, pppd/pppd.h,
pppd/sys-rtems.c: Add server with pap-authorization
capabilities as well as eliminate some warnings.
* pppd/rtemspppd.c (rtems_pppd_disconnect): Modified to avoid bringing
the link down too fast.
NOTE: Mike reports successfully running at 56K baud on a direct link.
* pppd/rtemsdialer.h: New file missed in previous commit.
* Nice Update of PPPD support which eliminates the
requiremetn that drivers be in the termios TASK_DRIVEN mode.
Mike did significant testing and reports that it seems to be
more stable and handle larger packets better. This patch
replaces the termios tasks with more general pppd network
driver tasks. The functions pppinput() and pppstart() get
called from the interrupt service routine.
* Makefile.am, configure.ac, net/Makefile.am, net/bpf.h,
net/ethernet.h, net/if.c, net/if.h, net/if_arp.h, net/if_dl.h,
net/if_ethersubr.c, net/if_llc.h, net/if_loop.c, net/if_ppp.h,
net/if_pppvar.h, net/if_types.h, net/netisr.h, net/ppp-comp.h,
net/ppp_defs.h, net/pppcompress.h, net/radix.c, net/radix.h,
net/raw_cb.c, net/raw_cb.h, net/raw_usrreq.c, net/route.c,
net/route.h, net/rtsock.c, pppd/Makefile.am, pppd/README,
pppd/STATUS, pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/ccp.h,
pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h,
pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c,
pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h,
pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h,
pppd/pathnames.h, pppd/pppd.8, pppd/pppd.h, pppd/rtemsmain.c,
pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/upap.c,
pppd/upap.h, pppd/utils.c, pppd/example/README,
pppd/example/netconfig.h, wrapup/Makefile.am: Modified.
* net/bsd-comp.c, net/if_ppp.c, net/ppp-deflate.c, net/ppp.h,
net/ppp_tty.c, net/pppcompress.c, net/zlib.c, net/zlib.h: New file.
* modem/, modem/.cvsignore, modem/Makefile.am, modem/ppp.c,
modem/ppp.h, modem/ppp_tty.c, modem/pppcompress.c: Subdirectory removed.
* pppd/sys-rtems.c: Remove unused variable status from
dodefaultroute.
* Update to stable working state. Congratulations Mike! :)
* modem_example: Directory removed.
* modem_example/16550.h, modem_example/README, modem_example/modem.c,
modem_example/modem.h, modem_example/ppp.c, modem_example/ppp.h,
modem_example/pppcompress.c: Files removed.
* pppd/example/pppd.options: New file.
* pppd/README, pppd/STATUS, pppd/cbcp.c, pppd/cbcp.h, pppd/chat.c,
pppd/pppd.h, pppd/rtemsmain.c: Updated.
* machine/Makefile.am: Use 'PREINSTALL_FILES ='.
* net/Makefile.am: Use 'PREINSTALL_FILES ='.
* netinet/Makefile.am: Use 'PREINSTALL_FILES ='.
* vm/Makefile.am: Use 'PREINSTALL_FILES ='.
* pppd/Makefile.am: Use 'PREINSTALL_FILES ='.
* sys/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='.
* arpa/Makefile.am: Use 'PREINSTALL_FILES ='.
* nfs/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* pppd/STATUS: Updated by Joel based upon email from Mike.
* pppd/cbcp.c, pppd/cbcp.h: Readded files. These support callback
functionality that has not even been compiled under RTEMS yet.
