path: root/c/src/libmisc/monitor/symbols.h (follow)
* 2002-12-12 Ralf Corsepius <corsepius@faw.uni-ulm.de>Ralf Corsepius2002-12-121-62/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * .cvsignore: Moved to rtems/cpukit/libmisc. * ChangeLog: Moved to rtems/cpukit/libmisc. * Makefile.am: Moved to rtems/cpukit/libmisc. * README: Moved to rtems/cpukit/libmisc. * configure.ac: Moved to rtems/cpukit/libmisc. * capture/Makefile.am: Moved to rtems/cpukit/libmisc. * capture/README: Moved to rtems/cpukit/libmisc. * capture/capture-cli.c: Moved to rtems/cpukit/libmisc. * capture/capture-cli.h: Moved to rtems/cpukit/libmisc. * capture/capture.c: Moved to rtems/cpukit/libmisc. * capture/capture.h: Moved to rtems/cpukit/libmisc. * cpuuse/Makefile.am: Moved to rtems/cpukit/libmisc. * cpuuse/README: Moved to rtems/cpukit/libmisc. * cpuuse/cpuuse.c: Moved to rtems/cpukit/libmisc. * cpuuse/cpuuse.h: Moved to rtems/cpukit/libmisc. * devnull/.cvsignore: Moved to rtems/cpukit/libmisc. * devnull/Makefile.am: Moved to rtems/cpukit/libmisc. * devnull/devnull.c: Moved to rtems/cpukit/libmisc. * devnull/devnull.h: Moved to rtems/cpukit/libmisc. * dummy/.cvsignore: Moved to rtems/cpukit/libmisc. * dummy/Makefile.am: Moved to rtems/cpukit/libmisc. * dummy/README: Moved to rtems/cpukit/libmisc. * dummy/dummy.c: Moved to rtems/cpukit/libmisc. * dumpbuf/.cvsignore: Moved to rtems/cpukit/libmisc. * dumpbuf/Makefile.am: Moved to rtems/cpukit/libmisc. * dumpbuf/dumpbuf.c: Moved to rtems/cpukit/libmisc. * dumpbuf/dumpbuf.h: Moved to rtems/cpukit/libmisc. * monitor/.cvsignore: Moved to rtems/cpukit/libmisc. * monitor/Makefile.am: Moved to rtems/cpukit/libmisc. * monitor/README: Moved to rtems/cpukit/libmisc. * monitor/mon-command.c: Moved to rtems/cpukit/libmisc. * monitor/mon-config.c: Moved to rtems/cpukit/libmisc. * monitor/mon-dname.c: Moved to rtems/cpukit/libmisc. * monitor/mon-driver.c: Moved to rtems/cpukit/libmisc. * monitor/mon-extension.c: Moved to rtems/cpukit/libmisc. * monitor/mon-itask.c: Moved to rtems/cpukit/libmisc. * monitor/mon-manager.c: Moved to rtems/cpukit/libmisc. * monitor/mon-monitor.c: Moved to rtems/cpukit/libmisc. * monitor/mon-mpci.c: Moved to rtems/cpukit/libmisc. * monitor/mon-object.c: Moved to rtems/cpukit/libmisc. * monitor/mon-prmisc.c: Moved to rtems/cpukit/libmisc. * monitor/mon-queue.c: Moved to rtems/cpukit/libmisc. * monitor/mon-server.c: Moved to rtems/cpukit/libmisc. * monitor/mon-symbols.c: Moved to rtems/cpukit/libmisc. * monitor/mon-task.c: Moved to rtems/cpukit/libmisc. * monitor/monitor.h: Moved to rtems/cpukit/libmisc. * monitor/symbols.h: Moved to rtems/cpukit/libmisc. * mw-fb/.cvsignore: Moved to rtems/cpukit/libmisc. * mw-fb/Makefile.am: Moved to rtems/cpukit/libmisc. * mw-fb/mw_fb.c: Moved to rtems/cpukit/libmisc. * mw-fb/mw_fb.h: Moved to rtems/cpukit/libmisc. * mw-fb/mw_uid.c: Moved to rtems/cpukit/libmisc. * mw-fb/mw_uid.h: Moved to rtems/cpukit/libmisc. * rtmonuse/.cvsignore: Moved to rtems/cpukit/libmisc. * rtmonuse/Makefile.am: Moved to rtems/cpukit/libmisc. * rtmonuse/rtmonuse.c: Moved to rtems/cpukit/libmisc. * rtmonuse/rtmonuse.h: Moved to rtems/cpukit/libmisc. * serdbg/.cvsignore: Moved to rtems/cpukit/libmisc. * serdbg/Makefile.am: Moved to rtems/cpukit/libmisc. * serdbg/README: Moved to rtems/cpukit/libmisc. * serdbg/serdbg.c: Moved to rtems/cpukit/libmisc. * serdbg/serdbg.h: Moved to rtems/cpukit/libmisc. * serdbg/serdbgcnf.h: Moved to rtems/cpukit/libmisc. * serdbg/serdbgio.c: Moved to rtems/cpukit/libmisc. * serdbg/termios_printk.c: Moved to rtems/cpukit/libmisc. * serdbg/termios_printk.h: Moved to rtems/cpukit/libmisc. * serdbg/termios_printk_cnf.h: Moved to rtems/cpukit/libmisc. * shell/.cvsignore: Moved to rtems/cpukit/libmisc. * shell/Makefile.am: Moved to rtems/cpukit/libmisc. * shell/README: Moved to rtems/cpukit/libmisc. * shell/cmds.c: Moved to rtems/cpukit/libmisc. * shell/shell.c: Moved to rtems/cpukit/libmisc. * shell/shell.h: Moved to rtems/cpukit/libmisc. * stackchk/.cvsignore: Moved to rtems/cpukit/libmisc. * stackchk/Makefile.am: Moved to rtems/cpukit/libmisc. * stackchk/README: Moved to rtems/cpukit/libmisc. * stackchk/check.c: Moved to rtems/cpukit/libmisc. * stackchk/internal.h: Moved to rtems/cpukit/libmisc. * stackchk/stackchk.h: Moved to rtems/cpukit/libmisc. * untar/.cvsignore: Moved to rtems/cpukit/libmisc. * untar/Makefile.am: Moved to rtems/cpukit/libmisc. * untar/README: Moved to rtems/cpukit/libmisc. * untar/untar.c: Moved to rtems/cpukit/libmisc. * untar/untar.h: Moved to rtems/cpukit/libmisc. * wrapup/.cvsignore: Moved to rtems/cpukit/libmisc. * wrapup/Makefile.am: Moved to rtems/cpukit/libmisc.
* Cleaned up as part of adding the Monitor test.Joel Sherrill1997-09-211-6/+4
* updates from Tony BennettJoel Sherrill1996-04-221-11/+0
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-10/+5
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Initial revisionJoel Sherrill1995-05-111-0/+80
