* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-11 | 1 | -250/+0 |
| | | | | | | | | | | | | | | and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP. | ||||
* | Split out the routine rtems_assoc_name_bad(). | Joel Sherrill | 1999-05-27 | 1 | -14/+4 |
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 1 | -3/+0 |
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 1 | -36/+41 |
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 1 | -0/+258 |
(tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables |
