* libblock, libfs moved to src/exec for multilib'ing.
* src/imfs/imfs_eval.c: Include <rtems/seterr.h>.
Apply rtems_set_errno_and_return_minus_one.
* src/imfs/memfile.c: Include <rtems/seterr.h>.
* src/imfs/imfs_readlink.c: Include <rtems/seterr.h>.
* src/imfs/imfs_unlink.c: Include <rtems/seterr.h>.
* src/imfs/imfs_link.c: Include <rtems/seterr.h>.
* src/imfs/imfs_chown.c: Include <rtems/seterr.h>.
* src/imfs/ioman.c: Include <rtems/seterr.h>.
* src/imfs/imfs_mount.c: Include <rtems/seterr.h>.
* src/imfs/imfs_directory.c: Include <rtems/seterr.h>.
* src/imfs/imfs_stat.c: Include <rtems/seterr.h>.
* src/imfs/imfs_fchmod.c: Include <rtems/seterr.h>.
* src/imfs/imfs_symlink.c: Include <rtems/seterr.h>.
* src/imfs/imfs_mknod.c: Include <rtems/seterr.h>.
* src/imfs/linearfile.c: Include <rtems/seterr.h>.
* src/imfs/imfs_unmount.c: Include <rtems/seterr.h>.
* src/imfs/imfs.h: Apply rtems_set_errno_and_return_minus_one.
Comment out increment_and_check_linkcounts.
* src/imfs/imfs.h, src/imfs/imfs_creat.c, src/imfs/imfs_debug.c,
src/imfs/imfs_eval.c, src/imfs/imfs_fchmod.c,
src/imfs/imfs_handlers_memfile.c, src/imfs/imfs_init.c,
src/imfs/imfs_initsupp.c, src/imfs/imfs_stat.c, src/imfs/memfile.c,
src/imfs/miniimfs_init.c: Final developmental update to "tarfs".
When rtems_tarfs_load() is called, it checks the permissions
on each file. If there is write permission, it just creates a
standard file using "creat()" and therefore, uses the IMFS MEMORY_FILE.
If there is no write permission, it creates a LINEAR_FILE node
with the appropriate properties. If the permission is ever changed
to writeable, IMFS_fchmod converts it to a regular memory file.
* src/imfs/linearfile.c, src/imfs/imfs_load_tar.c: New files.
* src/imfs/Makefile.am, src/imfs/imfs.h,
src/imfs/imfs_eval.c, src/imfs/imfs_handlers_memfile.c,
src/imfs/imfs_init.c, src/imfs/imfs_initsupp.c,
src/imfs/imfs_stat.c, src/imfs/miniimfs_init.c: Added "tarfs".
This is not really a tar filesystem. It is a way to load a tar
image into the IMFS but actually leave bulky file contents in the
original tar image. It essentially adds the linear file type and
associated support and a loader routine.
Java folks including Oscar Martinez de la Torre <omt@wm.estec.esa.nl>.
and not handling every case properly.
should not have been. This required that IMFS_rmnod be split into
three separate (per file type) routines to avoid dependencies.
In the end, a miniIMFS application is 6K smaller than one using the
full IMFS.
readdir support. The next step is to add a mount table and configure
either the miniIMFS or the full IMFS at the application level.
Renamed IMFS handler tables to include IMFS prefix.
routine imfs_fcntl.c
rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory
too fast. Perhaps in the future, the places in IMFS that put a maximum
length name string on the stack and the jnode structure does not include
a maximu length name string can be fixed so this is not a problem.
PROBLEMS
can/will be fixed.
