path: root/c/src/libchip/shmdr/initlq.c (follow)
* bsps: Move shmdr to bspsSebastian Huber2018-04-091-32/+0
| | | | | | This patch is a part of the BSP source reorganization. Update #3285.
* 2004-03-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-231-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | * libchip/ide/ata.c, libchip/ide/ata_internal.h, libchip/ide/ide_controller.c, libchip/ide/ide_ctrl_cfg.h, libchip/ide/ide_ctrl_io.h, libchip/network/cs8900.c, libchip/network/dec21140.c, libchip/network/elnk.c, libchip/network/if_fxp.c, libchip/network/open_eth.c, libchip/network/open_eth.h, libchip/network/sonic.c, libchip/network/sonic.h, libchip/rtc/icm7170.c, libchip/rtc/icm7170.h, libchip/rtc/icm7170_reg.c, libchip/rtc/icm7170_reg2.c, libchip/rtc/icm7170_reg4.c, libchip/rtc/icm7170_reg8.c, libchip/rtc/m48t08.c, libchip/rtc/m48t08.h, libchip/rtc/m48t08_reg.c, libchip/rtc/m48t08_reg2.c, libchip/rtc/m48t08_reg4.c, libchip/rtc/m48t08_reg8.c, libchip/rtc/rtc.h, libchip/serial/mc68681.c, libchip/serial/mc68681.h, libchip/serial/mc68681_reg.c, libchip/serial/mc68681_reg2.c, libchip/serial/mc68681_reg4.c, libchip/serial/mc68681_reg8.c, libchip/serial/ns16550.c, libchip/serial/ns16550_p.h, libchip/serial/serial.h, libchip/serial/z85c30.c, libchip/serial/z85c30.h, libchip/serial/z85c30_p.h, libchip/serial/z85c30_reg.c, libchip/shmdr/addlq.c, libchip/shmdr/cnvpkt.c, libchip/shmdr/dump.c, libchip/shmdr/fatal.c, libchip/shmdr/getlq.c, libchip/shmdr/init.c, libchip/shmdr/initlq.c, libchip/shmdr/intr.c, libchip/shmdr/poll.c, libchip/shmdr/send.c, libchip/shmdr/shm_driver.h: Convert to using c99 fixed-size types.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | * addlq.c, cnvpkt.c, dump.c, fatal.c, getlq.c, getpkt.c, init.c, initlq.c, intr.c, mpci.h, mpisr.c, poll.c, receive.c, retpkt.c, send.c, setckvec.c, shm_driver.h: URL for license changed.
* Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h.Joel Sherrill1999-11-301-1/+1
| | | | | Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
* Initial revisionJoel Sherrill1995-05-111-0/+35
