Update #3285.
* libchip/display/disp_hcms29xx.c, libchip/flash/am29lv160.c,
libchip/i2c/i2c-2b-eeprom.c, libchip/i2c/i2c-ds1621.c,
libchip/i2c/spi-flash-m25p40.c, libchip/i2c/spi-fram-fm25l256.c,
libchip/i2c/spi-memdrv.c, libchip/rtc/ds1375.c: Eliminate use of GNU
old-style field designator extension as recommended by clang.
* libchip/rtc/ds1375-rtc.h, libchip/rtc/ds1375.c,
libchip/rtc/icm7170.c, libchip/rtc/icm7170_reg.c,
libchip/rtc/m48t08_reg.c, libchip/rtc/rtc.h: Use uintptr_t instead of
uint32_t.
* libchip/rtc/ds1375.c, libchip/rtc/mc146818a.c: Fix warnings. Reformat
as needed.
* libchip/rtc/ds1375.c, libchip/rtc/ds1375-rtc.h:
added CVS ID.
Avoid using 'stdio' before the system is up and fully
initialized.
* libchip/rtc/ds1375.c, libchip/rtc/ds1375-rtc.h,
* libchip/Makefile.am, libchip/preinstall.am:
added new driver for Maxim DS1375 i2c RTC.
