path: root/c/src/libblock (follow)
* 2002-05-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-2818-3619/+0
| | | | * libblock, libfs moved to src/exec for multilib'ing.
* 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-083-0/+8
| | | | | * src/ramdisk.c: include <string.h>. * src/blkdev.c: include <string.h>.
* 2002-04-03 Alexander Kukuta <kam@oktet.ru>Joel Sherrill2002-04-032-2/+7
| | | | | * include/rtems/bdbuf.h: Address PR168 by changing bdbuf_buffer.avl.bal and bdbuf_buffer.avl.cache to signed char instead of char.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-285-5/+11
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-03-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-211-5/+0
| | | | * ChangeLog: Undo incorrect addition of entry.
* 2002-03-21 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-03-211-0/+5
| | | | | * net/if_ppp.c, net/ppp_tty.c: Initial preparations for multiple PPPD connections.
* 2002-03-21 Alexander Kukuta <kam@oktet.ru>Joel Sherrill2002-03-213-610/+389
| | | | | | | * src/bdbuf.c (avl_insert, avl_remove): Reimplemented from scratch to avoid using GPLed sources in RTEMS core. * src/bdbuf.c, include/rtems/bdbuf.h: Remove "binary tree" implementation which was used for debugging only.
* 2002-02-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-2818-0/+3821
* Submitted by Victor V. Vengerov <vvv@oktet.ru> and merged into the RTEMS source. * ChangeLog, Makefile.am, README, configure.ac, include/Makefile.am, include/rtems/bdbuf.h, include/rtems/blkdev.h, include/rtems/diskdevs.h, include/rtems/ramdisk.h, include/rtems/.cvsignore, include/.cvsignore, src/Makefile.am, src/bdbuf.c, src/blkdev.c, src/diskdevs.c, src/ramdisk.c, src/.cvsignore, .cvsignore: New files.
