* | cat /tmp/j | while read f | Joel Sherrill | 1999-10-26 | 1 | -449/+0 |
| | | | | | | do rpm -qi $f 2>&1 | grep -v "is not ins" done | ||||
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 1 | -0/+6 |
| | | | | it work. | ||||
* | Removed warnings. | Joel Sherrill | 1997-11-29 | 1 | -1/+1 |
* | Cleaned up as part of adding the Monitor test. | Joel Sherrill | 1997-09-21 | 1 | -1/+1 |
* | casts added to numerous arguments, prototypes corrected, and | Joel Sherrill | 1996-09-18 | 1 | -1/+1 |
| | | | | proper include files added. | ||||
* | updates from Tony Bennett | Joel Sherrill | 1996-04-22 | 1 | -9/+5 |
* | Update from Tony Bennett (tbennett@divnc.com) | Joel Sherrill | 1996-01-17 | 1 | -20/+24 |
* | updates from Tony Bennett for PA and UNIX ports | Joel Sherrill | 1996-01-15 | 1 | -1/+3 |
* | all targets compile .. tony's patches in place | Joel Sherrill | 1995-09-29 | 1 | -8/+8 |
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 1 | -7/+410 |
| | | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables | ||||
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+38 |
