path: root/c/src/lib/libcpu/sh/sh7045/null/Makefile.in (follow)
* Removing Makefile.in and adding Makefile.am. These were missed in conversionJoel Sherrill1999-12-211-238/+0
| | | | to automake by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Patch rtems-rc-19991203-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-211-44/+212
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which adds partial automake support to libcpu/<cpu>/*. Until now I have only implemented full automake support for the sh (my demonstration example :) and the i386 (inevitiable for structural reasons of this subdirectory). For all other cpus only their toplevel directories (exception: powerpc), include subdirectories and a few selected subdirectories have been converted to automake. I did this on purpose, because add automake support to each subdirectory requires individual adaptations which to be tested individually. Additionally the weirdnesses of the powerpc subdirectories hit again, esp. some powerpc cpu-models * install files to $(PROJECT_INCLUDE)/<cpu-model>/ while others install them to $(PROJECT_INCLUDE)/ * the scheme used to configure libcpu/powerpc/ is difficult to implement using automake, therefore this subdirectory still is configured by autoconf (The one out of an unlimited set selection scheme hits again :), though powerpc/*/* subdirectories already apply automake. The patch also reveils structural weaknesses in RTEMS: E.g. There seem to exist at least 5 different general schemes: * Not using libcpu at all (eg. i960) * Strictly tree-style a libcpu/<cpu-variant>/* (eg. m68k, sh) * Flat libcpu directory layout with cpu-variants merged into sources or not destinguishing cpu-variants (i386) * Not supporting variants with deep source tree (sparc, hppa, mips64orion) * Woven directory structure with shared directories (powerpc) I regret having to say this, but from my POV this means, that there doesn't exist a general implementation scheme for libcpu at all. To apply: rm -rf ./c/src/lib/libcpu/i386/wrapup rm -rf ./c/src/lib/libcpu/mips64orion/include rm -rf ./c/src/lib/libcpu/powerpc/ppc403/include patch -p1 < rtems-rc-19991203-7.diff ./bootstrap
* Patch rtems-rc-19991117-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-1/+1
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Patch from "John M. Mills" <jmills@tga.com> with subsequent cleanup fromJoel Sherrill1999-11-181-0/+70
Ralf Corsepius <corsepiu@faw.uni-ulm.de> that adds initial Hitachi SH-2 support to RTEMS. Ralf's comments are: Changes: ------ 1. SH-Port: * Many files renamed. * CONSOLE_DEVNAME and MHZ defines removed from libcpu. * console.c moved to libbsp/sh/shared, build in libbsp/sh/<BSP>/console applying VPATH. * CONSOLE_DEVNAME made BSP-specific, replacement is defined in bsp.h * MHZ define replaced with HZ (extendent resolution) in custom/*.cfg * -DHZ=HZ used in bspstart.c, only * Makefile variable HZ used in bsp-dependent directories only. 2. SH1-Port * clock-driver rewritten to provide better resolution for odd CPU frequencies. This driver is only partially tested on hardware, ie. sightly experimental, but I don't expect severe problems with it. * Polling SCI-driver added. This driver is experimental and completly untested yet. Therefore it is not yet used for the console (/dev/console is still pointing to /dev/null, cf. gensh1/bsp.h). * minor changes to the timer driver * SH1 specific delay()/CPU_delay() now is implemented as a function 3. SH2-Port * Merged * IMO, the code is still in its infancy. Therefore I have interspersed comments (FIXME) it for items which I think John should look after. * sci and console drivers partially rewritten and extended (John, I hope you don't mind). * Copyright notices are not yet adapted
