Update #3285.
Closes #3015.
Close #2237.
This commit covers at least PR2020, 2022, and 2023. This
patch adds all of the code for both BSPs, modifications
to libcpu/powerpc for the ppc440, and some updates to the
BSPs from follow up review and testing.
These BSPs should be good baselines for future development.
The configurations used by Ric are custom and have a non-standard
NIC. They also do not have a UART. Thus the current console
driver just prints to a RAM buffer.
The NIC and UART support are left for future work. When the UART
support is added, moving the existing "to RAM" console driver to
a shared location is likely desirable because boards with no debug
UART port are commonly deployed. This would let printk() go to RAM.
Rework of the start sequence to reduce the amount assembler code and to
support configuration tables which may be provided by the application.
* shared/include/cpuIdent.c, shared/include/cpuIdent.h
(get_ppc_cpu_type_name): Return const char*.
* new-exceptions/bspsupport/ppc_exc_categories.c,
shared/include/cpuIdent.c, shared/include/cpuIdent.h: Support e200z7.
* mpc6xx/clock/c_clock.c, mpc6xx/mmu/mmuAsm.S,
new-exceptions/bspsupport/ppc_exc_global_handler.c,
shared/include/cpuIdent.c, shared/src/stack.c: Update due to API
changes.
* mpc5xx/exceptions/raw_exception.c, mpc5xx/exceptions/raw_exception.h,
mpc5xx/include/console.h, mpc5xx/include/mpc5xx.h, mpc5xx/irq/irq.c,
mpc5xx/irq/irq.h, mpc5xx/irq/irq_asm.S, mpc5xx/vectors/vectors.h,
mpc5xx/vectors/vectors_init.c, mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h,
mpc6xx/mmu/mmuAsm.S, new-exceptions/bspsupport/irq.c,
new-exceptions/bspsupport/irq_supp.h,
new-exceptions/bspsupport/nested_irq_test.c,
new-exceptions/bspsupport/ppc_exc_address.c,
new-exceptions/bspsupport/ppc_exc_hdl.c,
new-exceptions/bspsupport/ppc_exc_initialize.c,
new-exceptions/bspsupport/ppc_exc_prologue.c,
new-exceptions/bspsupport/ppc_exc_test.c,
new-exceptions/bspsupport/vectors.h, shared/include/byteorder.h,
shared/include/cpuIdent.c, shared/include/cpuIdent.h,
shared/include/io.h, shared/include/mmu.h, shared/include/page.h,
shared/include/pgtable.h, shared/include/spr.h: Fix typo where
license said found in found in.
* shared/include/cpuIdent.c, shared/include/cpuIdent.h: Added support
for e500v2. Removed IVPR/IVOR/HWIVOR features since they are included
in Book E.
* new-exceptions/bspsupport/vectors.h,
new-exceptions/bspsupport/ppc_exc.S,
new-exceptions/bspsupport/ppc_exc_prologue.c: Added support for
e500v2. Added exception vector defines for Book E types. Removed
e200 exception vector defines. Added e500 exception vector defines.
Unified IVOR calculation for e200 and e500 (e200z1 has hard wired
IVOR values).
* shared/include/cpuIdent.c: Set 604 features + altivec if
running on PSIM.
* mpc6xx/mmu/bat.c, new-exceptions/e500_raw_exc_init.c,
new-exceptions/raw_exception.h, new-exceptions/bspsupport/irq_supp.h,
shared/include/cpuIdent.c: Removed warnings. Split
bsp_irq_dispatch_list to allow non-standard/non-existant pics to call
with interrupts off.
* mpc55xx/fec/fec.c: Added copyright information.
* mpc55xx/dspi/dspi.c, mpc55xx/edma/edma.c, mpc55xx/esci/esci.c:
Fixed nexted extern declarations. Fixed integer conversion warnings.
* shared/include/cpuIdent.c: Added missing initializers.
* new-exceptions/e500_raw_exc_init.c, new-exceptions/raw_exception.c,
Added different kinds of 'bookE' to the ppc_cpu_is_bookE feature
check; unfortunately...
* shared/include/cpuIdent.h, shared/include/cpuIdent.c:
added feature check for 603 'TLBMISS exception GPRS shadowing'.
Added a simple 'feature check' facility. Code should
not check for a particular CPU type if possible but
check the respective feature bit (e.g., 'has_altivec').
This makes it much less cumbersome to add more CPU
types in the future.
known variant.
* ChangeLog, configure.ac, mpc6xx/exceptions/raw_exception.c,
shared/include/cpuIdent.c, shared/include/cpuIdent.h: recognize
mpc7457 CPU; added definitions for high bats (#4..7) on 7450 CPUs
* powerpc/shared/include/cpuIdent.c,
powerpc/shared/include/cpuIdent.h: Add 603le.
(Submitted by Thomas.Doerfler <Thomas.Doerfler@imd-systems.de>
as part of the patch attached to PR 703).
* configure.ac, mpc6xx/exceptions/raw_exception.c,
mpc6xx/exceptions/raw_exception.h, mpc6xx/mmu/bat.c,
mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S, shared/include/cpuIdent.c,
shared/include/cpuIdent.h: Add MPC8240 and MPC8245 support. There was
also a significant amount of spelling and whitespace cleanup.
PR 587/bsps
* shared/include/cpuIdent.h, shared/include/cpuIdent.c: Add defines
for MPC_5XX.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h,
mpc6xx/exceptions/raw_exception.c, mpc6xx/exceptions/raw_exception.h,
mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S,
mpc6xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/brg.c,
mpc8260/exceptions/raw_exception.c,
mpc8260/exceptions/raw_exception.h, mpc8260/include/cpm.h,
mpc8260/include/mmu.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c,
mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
mpc8xx/exceptions/raw_exception.c, mpc8xx/exceptions/raw_exception.h,
mpc8xx/include/cpm.h, mpc8xx/include/mmu.h, mpc8xx/mmu/mmu.c,
mpc8xx/timer/timer.c, ppc403/clock/clock.c,
ppc403/console/console.c.polled, ppc403/timer/timer.c,
rtems/powerpc/debugmod.h, shared/include/byteorder.h,
shared/include/pgtable.h, shared/include/spr.h: URL for license
changed.
PR 349/bsps
* shared/include/cpuIdent.c: Readd PPC604r CPU.
PR 349/bsps
* mpc6xx/exceptions/raw_exception.c, mpc6xx/mmu/bat.c,
mpc6xx/mmu/pte121.c, shared/include/cpuIdent.c,
shared/include/cpuIdent.h, shared/src/Makefile.am, shared/src/stack.c,
shared/src/stackTrace.h, powerpc/registers.h:
- undo improper 'fix' who broke mpc604r identification
- fix: 7400 identification PVR value was wrong
- enhance 'setdbat()' to switch OFF a given BAT if called with 0 size
- fix: page table support bugfix
- enhancement: provide routines to take and print stack trace
snapshots
- add definitions for HID1 and DABR SPRs
* shared/include/cpuIdent.c: Account for duplicate numbers.
* rtems/powerpc/registers.h, rtems/score/ppc.h: Per PR213, add
the following:
- support for the MPC74000 (AKA G4); there is no
AltiVec support yet, however.
- the cache flushing assembly code uses hardware-flush on the G4.
Also, a couple of hardcoded numerical values were replaced
by more readable symbolic constants.
- extended interrupt-disabled code section so enclose the entire
cache flush/invalidate procedure (as recommended by the book).
This is not (latency) critical as it is only used by
init code but prevents possible corruption.
- Trivial page table support as been added.
(1:1 effective-virtual-physical address mapping which is only
useful only on CPUs which feature hardware TLB replacement,
e.g. >604. This allows for write-protecting memory regions,
e.g. text/ro-data which makes catching corruptors a lot easier.
It also frees one DBAT/IBAT and gives more flexibility
for setting up address maps :-)
- setdbat() allows changing BAT0 also (since the BSP may use
a page table, BAT0 could be available...).
- asm_setdbatX() violated the SVR ABI by using
r20 as a scratch register; changed for r0
- according to the book, a context synchronizing instruction is
necessary prior to and after changing a DBAT -> isync added
* shared/include/cpuIdent.h: New.
* shared/include/cpuIdent.c: Reflect having added cpuIdent.h.
* shared/include/cpu.h: Ditto.
* shared/include/Makefile.am: Add cpuIndent.h. Fix EXTRA_DIST.
* mpc6xx/clock/c_clock.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc6xx/mmu/bat.h: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/cpm/brg.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8xx/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/include/cpuIdent.c: Include rtems/bspIo.h instead of bspIo.h.
* Makefile.am, README, configure.ac, new_exception_processing/cpu.h,
shared/include/cpu.h, shared/include/cpuIdent.c, shared/src/cache.c:
Added mpc8260 support.
shared source code.
