line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* e500/mmu/mmu.c, mpc505/ictrl/ictrl.c, mpc505/timer/timer.c,
mpc5xx/ictrl/ictrl.c, mpc5xx/timer/timer.c,
mpc6xx/altivec/vec_sup.c, mpc6xx/clock/c_clock.c,
mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/pte121.c,
mpc8260/timer/timer.c, mpc8xx/timer/timer.c, new-exceptions/cpu.c,
new-exceptions/bspsupport/ppc_exc_initialize.c,
ppc403/clock/clock.c, ppc403/console/console.c,
ppc403/console/console.c.polled, ppc403/console/console405.c,
ppc403/irq/ictrl.c, ppc403/tty_drv/tty_drv.c,
rtems/powerpc/cache.h, shared/include/powerpc-utility.h, shared/src/cache.c:
* mpc8xx/mmu/mmu.c, rtems/powerpc/cache.h, rtems/powerpc/powerpc.h:
#include <rtems/powerpc/powerpc.h>.
* rtems/powerpc/cache.h, rtems/powerpc/debugmod.h:
New header guards.
* mpc505/ictrl/ictrl.c, mpc505/vectors/vectors.S,
mpc6xx/exceptions/raw_exception.c,
mpc8260/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.c, rtems/powerpc/cache.h,
mpc5xx/ictrl/ictrl.c, mpc5xx/exceptions/raw_exception.c: Include
<rtems/score/powerpc.h> instead of <rtems/score/ppc.h>.
* mpc505/timer/timer.c, mpc5xx/timer/timer.c,
mpc6xx/clock/c_clock.c, mpc6xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/cp.c,
mpc8260/cpm/dpram.c, mpc8260/include/cpm.h, mpc8260/include/mmu.h,
mpc8260/include/mpc8260.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c,
mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
mpc8xx/cpm/cp.c, mpc8xx/cpm/dpram.c, mpc8xx/include/cpm.h,
mpc8xx/include/mmu.h, mpc8xx/include/mpc8xx.h, mpc8xx/mmu/mmu.c,
mpc8xx/timer/timer.c, ppc403/clock/clock.c,
ppc403/console/console.c, ppc403/console/console405.c,
ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h, ppc403/timer/timer.c,
ppc403/tty_drv/tty_drv.c, rtems/powerpc/cache.h, shared/src/cache.c:
Convert to using c99 fixed size types.
* rtems/powerpc/cache.h: New file (extracted from
old-exceptions/cpu.h)
* Makefile.am: Relect changes above.
