line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
i2c-driver: wait, 'til stop executed
* mpc5xx/console-generic/console-generic.c, mpc5xx/include/console.h,
mpc8260/console-generic/console-generic.c, mpc8260/include/console.h,
mpc8xx/console-generic/console-generic.c, mpc8xx/include/console.h:
Remove all references to console_reserve_resources and
termios_reserve_resources.
PR 816/bsps
* mpc8xx/include/mpc8xx.h: The struct which describes SCC Ethernet mode
parameters (m8xxSCCENparms_t) does not match the hardware: members
taddr_h and taddr_l are transposed. When loading new multicast group
addresses into the hash table, the wrong hash bit is set.
* mpc505/timer/timer.c, mpc5xx/timer/timer.c,
mpc6xx/clock/c_clock.c, mpc6xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/cp.c,
mpc8260/cpm/dpram.c, mpc8260/include/cpm.h, mpc8260/include/mmu.h,
mpc8260/include/mpc8260.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c,
mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
mpc8xx/cpm/cp.c, mpc8xx/cpm/dpram.c, mpc8xx/include/cpm.h,
mpc8xx/include/mmu.h, mpc8xx/include/mpc8xx.h, mpc8xx/mmu/mmu.c,
mpc8xx/timer/timer.c, ppc403/clock/clock.c,
ppc403/console/console.c, ppc403/console/console405.c,
ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h, ppc403/timer/timer.c,
ppc403/tty_drv/tty_drv.c, rtems/powerpc/cache.h, shared/src/cache.c:
Convert to using c99 fixed size types.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h,
mpc6xx/exceptions/raw_exception.c, mpc6xx/exceptions/raw_exception.h,
mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/brg.c,
mpc8260/exceptions/raw_exception.c,
mpc8260/exceptions/raw_exception.h, mpc8260/include/cpm.h,
mpc8260/include/mmu.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c,
mpc8xx/exceptions/raw_exception.c, mpc8xx/exceptions/raw_exception.h,
mpc8xx/include/cpm.h, mpc8xx/include/mmu.h, mpc8xx/mmu/mmu.c,
ppc403/console/console.c.polled, ppc403/timer/timer.c,
rtems/powerpc/debugmod.h, shared/include/byteorder.h,
shared/include/cpuIdent.c, shared/include/cpuIdent.h,
shared/include/io.h, shared/include/mmu.h, shared/include/page.h,
shared/include/pgtable.h, shared/include/spr.h: URL for license
changed.
PR 368/filesystems
* mpc8xx/include/mpc8xx.h: Add PCMCIA registers.
* mpc8260/Makefile.am: Merge-in mpc8260/include/Makefile.am.
* mpc8xx/Makefile.am: Merge-in mpc8xx/include/Makefile.am.
* mpc8260/include/Makefile.am: Remove.
* mpc8xx/include/Makefile.am: Remove.
* configure.ac: Remove mpc8260/include/Makefile.
Remove mpc8xx/include/Makefile.
* mpc505/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/console/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/tty_drv/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'CLEANFILES ='.
* mpc8xx/exceptions/.cvsignore, mpc8xx/exceptions/Makefile.am,
mpc8xx/exceptions/asm_utils.S, mpc8xx/exceptions/raw_exception.c,
mpc8xx/exceptions/raw_exception.h: New files.
* configure.in, mpc6xx/mmu/bat.h, mpc8xx/Makefile.am,
new_exception_processing/cpu.h, shared/include/byteorder.h,
wrapup/Makefile.am: This is conversion of the
mpc8xx CPU to the "new exception processing model."
* mpc505/ictrl/Makefile.am, mpc6xx/clock/Makefile.am,
mpc6xx/exceptions/Makefile.am, mpc6xx/mmu/Makefile.am,
mpc8xx/include/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am, pc403/ictrl/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am:
Apply *_HEADERS instead of *H_FILES.
* shared/src/.cvsignore: Add cache.h.
* mpc505/timer/Makefile.am, mpc505/vectors/Makefile.am,
mpc6xx/clock/Makefile.am, mpc6xx/exceptions/Makefile.am,
mpc6xx/mmu/Makefile.am, mpc6xx/timer/Makefile.am,
mpc6xx/wrapup/Makefile.am, ppc403/clock/Makefile.am,
ppc403/console/Makefile.am, ppc403/ictrl/Makefile.am,
ppc403/timer/Makefile.am, ppc403/vectors/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am,
wrapup/Makefile.am, mpc8xx/clock/Makefile.am,
mpc8xx/console-generic/Makefile.am, mpc8xx/cpm/Makefile.am,
mpc8xx/mmu/Makefile.am, mpc8xx/timer/Makefile.am,
mpc8xx/vectors/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am: Include compile.am
mpc8xx libcpu support for the first time and remove includes
of bsp.h, references to BSP_Configuration, and Cpu_table. All
of these can be obtained directly from RTEMS now.
significant things:
and PowerPC
same code base.
