* | bsps/powerpc: Fix warning | Sebastian Huber | 2017-02-15 | 1 | -2/+0 |
* | bsp/mpc83xx: Update due to header guard change | Sebastian Huber | 2015-07-17 | 2 | -6/+6 |
| | | | | Close #2373. | ||||
* | bsps/mpc83xx: Fix warnings | Sebastian Huber | 2015-01-09 | 1 | -4/+5 |
* | bsps/powerpc: SMP support for one TSEC driver | Sebastian Huber | 2014-04-15 | 1 | -13/+16 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 8 | -8/+8 |
* | mpc83xx: Add and use mpc83xx_reset() | Sebastian Huber | 2013-03-14 | 1 | -0/+19 |
| | | | | | The inline version makes it possible to use this code in different memory areas. | ||||
* | bsps/powerpc: Add probe handler to I2C driver | Sebastian Huber | 2013-01-09 | 1 | -0/+1 |
* | bsps/powerpc: Fix compiler warnings | Sebastian Huber | 2013-01-09 | 1 | -4/+1 |
* | bsp/gen83xx: Add GPR_1 to register map | Sebastian Huber | 2012-12-21 | 1 | -1/+3 |
* | bsp/gen83xx: Fix RCWLR_CEVCO defines | Sebastian Huber | 2012-12-21 | 1 | -2/+3 |
* | libnetworking: Use system events | Sebastian Huber | 2012-11-02 | 1 | -3/+3 |
| | | | | | | | Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP. Add and use rtems_bsdnet_event_send(). | ||||
* | Use proper 3 line form of license text | Joel Sherrill | 2012-10-11 | 2 | -4/+6 |
* | bsp/gen83xx: Add br_uid BSP variant | Thomas Doerfler | 2012-08-20 | 1 | -0/+15 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -4/+0 |
* | 2011-11-10 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-11-10 | 1 | -4/+5 |
| | | | | | PR 1927/bsps: * mpc83xx/network/tsec.c: Fixed integer truncation. | ||||
* | 2011-09-27 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-26 | 2 | -7/+5 |
| | | | | | * mpc83xx/include/mpc83xx.h, mpc83xx/network/tsec.c: Update due to API changes. | ||||
* | 2011-02-25 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-02-25 | 1 | -22/+33 |
| | | | | | | * mpc83xx/network/tsec.c: New default MAC configuration. Set MDIO clock according to actual CCB frequency. Print media info only if we have a PHY. Avoid infinite loop in media adaption. | ||||
* | 2011-01-14 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-01-14 | 2 | -99/+51 |
| | | | | | | * mpc83xx/network/tsec.c, mpc83xx/network/tsec.h: Use configuration structure instead of many function parameters. Moved board specific initializations. Added support for interfaces without PHY access. | ||||
* | 2010-12-30 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-12-30 | 3 | -688/+612 |
| | | | | | | * mpc83xx/include/mpc83xx.h, mpc83xx/network/tsec.c, mpc83xx/network/tsec.h: Make it possible to use the TSEC driver for other systems. | ||||
* | 2010-12-23 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-12-23 | 1 | -1/+5 |
| | | | | | * mpc83xx/i2c/mpc83xx_i2cdrv.c: Fixed interrupt flag clearing for MPC55XX family. | ||||
* | 2010-11-12 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2010-11-12 | 3 | -50/+74 |
| | | | | | | | * mpc55xx/include/irq.h: Include missing <bspopts.h>. Format. * mpc83xx/include/mpc83xx.h, mpc83xx/i2c/mpc83xx_i2cdrv.h, mpc83xx/i2c/mpc83xx_i2cdrv.c: Changes to use this driver for the MPC55XX familiy. | ||||
* | code changes to remove warnings | Thomas Doerfler | 2010-03-27 | 1 | -59/+48 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 6 | -141/+141 |
* | shared/include/utility.h: Removed file. | Thomas Doerfler | 2008-10-10 | 1 | -4/+4 |
| | | | | | | shared/include/powerpc-utility.h: Use constraint "b" for address base registers in inline assembler statements. Update for status-checks.h changes. | ||||
* | 2008-10-01 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-10-01 | 1 | -0/+2 |
| | | | | | * mpc83xx/include/mpc83xx.h: #include <bspopts.h> to make sure defines from bspopts.h get propagated. | ||||
* | minor additions | Thomas Doerfler | 2008-09-09 | 1 | -1/+6 |
| | | | | i2c-driver: wait, 'til stop executed | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-06 | 1 | -1/+1 |
* | Convert to "bool". | Ralf Corsepius | 2008-09-05 | 1 | -8/+8 |
* | Eliminate rtems_boolean. | Ralf Corsepius | 2008-09-02 | 1 | -2/+2 |
* | various changes to gen83xx BSP and others | Thomas Doerfler | 2008-08-26 | 3 | -9/+82 |
* | 2008-08-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2008-08-20 | 1 | -4/+4 |
| | | | | | | | * mpc55xx/fec/fec.c: Added copyright information. * mpc55xx/dspi/dspi.c, mpc55xx/edma/edma.c, mpc55xx/esci/esci.c: Fixed nexted extern declarations. Fixed integer conversion warnings. * shared/include/cpuIdent.c: Added missing initializers. | ||||
* | Changed special purpose register inline functions to macros. | Thomas Doerfler | 2008-07-18 | 1 | -2/+2 |
| | | | | | fixed some minors in mpc83xx support added file for mpc55xx watchdog support | ||||
* | mpc8249eamds support for Gigabit Ethernet works again | Thomas Doerfler | 2008-07-18 | 1 | -9/+10 |
| | | | | initialize PHY registers late enough, so that phy access is possible | ||||
* | updated gen83xx BSP | Thomas Doerfler | 2008-07-14 | 6 | -26/+422 |
| | | | | | updated haleakala BSP added MPC55xx BSP | ||||
* | speed inprovements in mpc83xx tsec driver | Thomas Doerfler | 2008-05-27 | 1 | -1/+5 |
* | 2008-05-16 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-05-16 | 1 | -1/+5 |
| | | | | | * mpc83xx/include/mpc83xx.h: or is not a good name for any name in C/C++. See iso646.h for the reason. | ||||
* | disabled debugging output | Thomas Doerfler | 2008-05-15 | 1 | -1/+1 |
* | adapted gen83xx to new board | Thomas Doerfler | 2008-05-15 | 6 | -37/+97 |
* | added missing mpc83xx/spi driver | Thomas Doerfler | 2007-12-04 | 2 | -0/+838 |
* | added SPI support to libi2c | Thomas Doerfler | 2007-10-25 | 3 | -74/+236 |
| | | | | | added IRQ support to MPC83xx i2c driver added mpc83xx spi driver | ||||
* | added i2c support | Thomas Doerfler | 2007-08-10 | 3 | -6/+627 |
* | compilable release of virtex/gen83xx/gen5200 powerpc adaptations. Merged ↵ | Thomas Doerfler | 2007-07-10 | 3 | -0/+3140 |
many different versions of new exception handling code to shared sources. |
