Update #3285.
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
This is a preparation to remove the Giant lock.
Update #2555.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* mpc5xx/clock/clock.c, mpc5xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/cpm/brg.c, mpc8260/timer/timer.c, mpc8xx/clock/clock.c,
mpc8xx/console-generic/console-generic.c, mpc8xx/timer/timer.c,
new-exceptions/raw_exception.c, old-exceptions/cpu.c,
ppc403/clock/clock.c, ppc403/console/console.c,
ppc403/console/console.c.polled, ppc403/console/console405.c,
ppc403/ictrl/ictrl.c, ppc403/irq/ictrl.c, ppc403/timer/timer.c,
ppc403/tty_drv/tty_drv.c: Eliminate PowerPC specific elements from
the CPU Table. They have been replaced with variables named bsp_XXX
as needed.
* mpc8260/cpm/dpram.c, mpc8260/timer/timer.c, mpc8xx/cpm/dpram.c:
Remove warnings.
* mpc8260/cpm/dpram.c, mpc8xx/cpm/dpram.c:
Remove local rtems_panic, use #include <rtems/error.h>.
* mpc505/timer/timer.c, mpc5xx/timer/timer.c,
mpc6xx/clock/c_clock.c, mpc6xx/timer/timer.c, mpc8260/clock/clock.c,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/cp.c,
mpc8260/cpm/dpram.c, mpc8260/include/cpm.h, mpc8260/include/mmu.h,
mpc8260/include/mpc8260.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c,
mpc8xx/clock/clock.c, mpc8xx/console-generic/console-generic.c,
mpc8xx/cpm/cp.c, mpc8xx/cpm/dpram.c, mpc8xx/include/cpm.h,
mpc8xx/include/mmu.h, mpc8xx/include/mpc8xx.h, mpc8xx/mmu/mmu.c,
mpc8xx/timer/timer.c, ppc403/clock/clock.c,
ppc403/console/console.c, ppc403/console/console405.c,
ppc403/ictrl/ictrl.c, ppc403/ictrl/ictrl.h, ppc403/timer/timer.c,
ppc403/tty_drv/tty_drv.c, rtems/powerpc/cache.h, shared/src/cache.c:
Convert to using c99 fixed size types.
* mpc8260/clock/Makefile.am: Remove.
* mpc8260/console-generic/Makefile.am: Remove.
* mpc8260/cpm/Makefile.am: Remove.
* mpc8260/exceptions/Makefile.am: Remove.
* mpc8260/mmu/Makefile.am: Remove.
* mpc8260/timer/Makefile.am: Remove.
* mpc8260/Makefile.am: Merge-in Makefile.ams above.
* mpc505/ictrl/Makefile.am: Remove all-local: $(ARCH).
* mpc505/timer/Makefile.am: Remove all-local: $(ARCH).
* mpc505/vectors/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/clock/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/exceptions/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/mmu/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/timer/Makefile.am: Remove all-local: $(ARCH).
* mpc6xx/wrapup/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/clock/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/console-generic/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/cpm/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/exceptions/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/mmu/Makefile.am: Remove all-local: $(ARCH).
* mpc8260/timer/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/clock/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/console-generic/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/cpm/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/exceptions/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/mmu/Makefile.am: Remove all-local: $(ARCH).
* mpc8xx/timer/Makefile.am: Remove all-local: $(ARCH).
* ppc403/clock/Makefile.am: Remove all-local: $(ARCH).
* ppc403/console/Makefile.am: Remove all-local: $(ARCH).
* ppc403/ictrl/Makefile.am: Remove all-local: $(ARCH).
* ppc403/timer/Makefile.am: Remove all-local: $(ARCH).
* ppc403/tty_drv/Makefile.am: Remove all-local: $(ARCH).
* ppc403/vectors/Makefile.am: Remove all-local: $(ARCH).
* shared/include/Makefile.am: Remove all-local: $(ARCH).
* shared/src/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc505/Makefile.am: Reformat.
* mpc505/ictrl/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc505/timer/Makefile.am: Reformat.
* mpc505/vectors/Makefile.am: Reformat.
* mpc6xx/Makefile.am: Reformat.
* mpc6xx/clock/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/mmu/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc6xx/timer/Makefile.am: Reformat.
* mpc6xx/wrapup/Makefile.am: Reformat.
* mpc8260/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8260/clock/Makefile.am: Reformat.
* mpc8260/console-generic/Makefile.am: Reformat.
* mpc8260/cpm/Makefile.am: Reformat.
* mpc8260/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8260/mmu/Makefile.am: Reformat.
* mpc8260/timer/Makefile.am: Reformat.
* mpc8xx/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8xx/clock/Makefile.am: Reformat.
* mpc8xx/console-generic/Makefile.am: Reformat.
* mpc8xx/cpm/Makefile.am: Reformat.
* mpc8xx/exceptions/Makefile.am: Reformat. Use dirstamp for preinstallation.
* mpc8xx/mmu/Makefile.am: Reformat.
* mpc8xx/timer/Makefile.am: Reformat.
* ppc403/Makefile.am: Reformat.
* ppc403/clock/Makefile.am: Reformat.
* ppc403/console/Makefile.am: Reformat.
* ppc403/ictrl/Makefile.am: Reformat. Use dirstamp for preinstallation.
* ppc403/timer/Makefile.am: Reformat.
* ppc403/tty_drv/Makefile.am: Reformat. Use dirstamp for preinstallation.
* ppc403/vectors/Makefile.am: Reformat.
* shared/Makefile.am: Reformat.
* shared/include/Makefile.am: Reformat. Use dirstamp for preinstallation.
* shared/src/Makefile.am: Reformat. Use dirstamp for preinstallation.
* wrapup/Makefile.am: Reformat.
* mpc6xx/clock/c_clock.c, mpc6xx/clock/c_clock.h,
mpc6xx/exceptions/raw_exception.c, mpc6xx/exceptions/raw_exception.h,
mpc6xx/mmu/bat.c, mpc6xx/mmu/bat.h, mpc6xx/mmu/mmuAsm.S,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/brg.c,
mpc8260/exceptions/raw_exception.c,
mpc8260/exceptions/raw_exception.h, mpc8260/include/cpm.h,
mpc8260/include/mmu.h, mpc8260/mmu/mmu.c, mpc8260/timer/timer.c,
mpc8xx/exceptions/raw_exception.c, mpc8xx/exceptions/raw_exception.h,
mpc8xx/include/cpm.h, mpc8xx/include/mmu.h, mpc8xx/mmu/mmu.c,
ppc403/console/console.c.polled, ppc403/timer/timer.c,
rtems/powerpc/debugmod.h, shared/include/byteorder.h,
shared/include/cpuIdent.c, shared/include/cpuIdent.h,
shared/include/io.h, shared/include/mmu.h, shared/include/page.h,
shared/include/pgtable.h, shared/include/spr.h: URL for license
changed.
mpc505/Makefile.am: Reflect having moved automake.
mpc505/ictrl/Makefile.am: Reflect having moved automake.
mpc505/timer/Makefile.am: Reflect having moved automake.
mpc505/vectors/Makefile.am: Reflect having moved automake.
mpc6xx/Makefile.am: Reflect having moved automake.
mpc6xx/clock/Makefile.am: Reflect having moved automake.
mpc6xx/exceptions/Makefile.am: Reflect having moved automake.
mpc6xx/mmu/Makefile.am: Reflect having moved automake.
mpc6xx/timer/Makefile.am: Reflect having moved automake.
mpc6xx/wrapup/Makefile.am: Reflect having moved automake.
mpc8260/Makefile.am: Reflect having moved automake.
mpc8260/clock/Makefile.am: Reflect having moved automake.
mpc8260/console-generic/Makefile.am: Reflect having moved automake.
mpc8260/cpm/Makefile.am: Reflect having moved automake.
mpc8260/exceptions/Makefile.am: Reflect having moved automake.
mpc8260/mmu/Makefile.am: Reflect having moved automake.
mpc8260/timer/Makefile.am: Reflect having moved automake.
mpc8xx/Makefile.am: Reflect having moved automake.
mpc8xx/clock/Makefile.am: Reflect having moved automake.
mpc8xx/console-generic/Makefile.am: Reflect having moved automake.
mpc8xx/cpm/Makefile.am: Reflect having moved automake.
mpc8xx/exceptions/Makefile.am: Reflect having moved automake.
mpc8xx/mmu/Makefile.am: Reflect having moved automake.
mpc8xx/timer/Makefile.am: Reflect having moved automake.
ppc403/Makefile.am: Reflect having moved automake.
ppc403/clock/Makefile.am: Reflect having moved automake.
ppc403/console/Makefile.am: Reflect having moved automake.
ppc403/ictrl/Makefile.am: Reflect having moved automake.
ppc403/timer/Makefile.am: Reflect having moved automake.
ppc403/tty_drv/Makefile.am: Reflect having moved automake.
ppc403/vectors/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/include/Makefile.am: Reflect having moved automake.
shared/src/Makefile.am: Reflect having moved automake.
* configure.ac: Remove RTEMS_CHEC_CUSTOM_BSP.
* mpc505/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc505/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc6xx/wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/console-generic/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/cpm/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/exceptions/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/mmu/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8xx/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/clock/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/console/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/ictrl/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/tty_drv/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* ppc403/vectors/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/include/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* shared/src/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* mpc8260/console-generic/console-generic.c, mpc8260/cpm/dpram.c,
mpc8xx/exceptions/raw_exception.c: Removed warnings.
* mpc505/ictrl/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc505/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc505/vectors/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc6xx/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/console-generic/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/cpm/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8260/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/console-generic/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/cpm/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/exceptions/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/mmu/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc8xx/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/console/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/ictrl/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/tty_drv/Makefile.am: Use .$(OBJEXT) instead of .o.
* ppc403/vectors/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/include/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/src/Makefile.am: Use .$(OBJEXT) instead of .o.
* mpc505/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc505/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8260/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/console-generic/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/cpm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/exceptions/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/mmu/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc8xx/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/clock/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/console/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/ictrl/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/timer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/tty_drv/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ppc403/vectors/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mpc6xx/clock/c_clock.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc6xx/mmu/bat.h: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8260/cpm/brg.c: Include rtems/bspIo.h instead of bspIo.h.
* mpc8xx/console-generic/console-generic.c: Include rtems/bspIo.h instead of bspIo.h.
* shared/include/cpuIdent.c: Include rtems/bspIo.h instead of bspIo.h.
* Added mpc8260 directory.
* Modified Makefile.am and configure.in to build the contents
* mpc8260/Makefile.am, mpc8260/README, mpc8260/clock/Makefile.am,
mpc8260/clock/clock.c, mpc8260/console-generic/Makefile.am,
mpc8260/console-generic/console-generic.c, mpc8260/cpm/.cvsignore,
mpc8260/cpm/Makefile.am, mpc8260/cpm/brg.c, mpc8260/cpm/cp.c,
mpc8260/cpm/dpram.c, mpc8260/exceptions/.cvsignore,
mpc8260/exceptions/Makefile.am, mpc8260/exceptions/asm_utils.S,
mpc8260/exceptions/raw_exception.c, mpc8260/exceptions/raw_exception.h,
mpc8260/include/Makefile.am, mpc8260/include/console.h,
mpc8260/include/mpc8260.h, mpc8260/mmu/Makefile.am, mpc8260/mmu/mmu.c,
mpc8260/timer/Makefile.am, mpc8260/timer/timer.c: New files.
