* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 1 | -29/+0 |
| | | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -4/+2 |
* | Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from | Joel Sherrill | 2000-01-31 | 1 | -5/+6 |
| | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams | ||||
* | Patch rtems-rc-20000104-13.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-10 | 1 | -0/+30 |
which does the following: * some cleanups, fixes, addtions to the libbsp automake transition patches * The missing Automake transistion patches all libcpu/<cpu>/<variant>/* previously not yet been converted to automake (libcpu/powerpc, libcpu/hppa1.1, libcpu/mips64orion, libcpu/sparc) => With this patch, libcpu/*/* is under full automake control. NOTES: * This patch is tested by building for random set of bsps affected by this patch, but not tested for all BSPs. * The parts of this patch related to libcpu/powerpc fix many small bugs inside of those Makefiles. * Have a look into libcpu/powerpc/mpc6xx/, which is in rather bad shape, IMO. Obviously most subdirectories seem to be build but are not included into libcpu.a by wrapup/Makefile. Addtionally, no actual BSP uses this cpu-variant subdirectory. Furthermore libcpu/powerpc/mpc6xx has a different directory layout than all other powerpc/<variant>/ directories. Joel's note: I agree but the issue is that there is a conflict between including timer or clock in libcpu/XXX/wrapup/Makefile.* and letting a BSP specifically decide to pick it up. There is no clear solution to this at the moment. |
