Putting the duart in libcpu was very optimistic and presumptuous.
It has never been used again on another SoC and is BSP specific.
* mongoosev/duart/mg5uart.c, mongoosev/include/mongoose-v.h,
mongoosev/vectorisrs/vectorisrs.c,
shared/interrupts/vectorexceptions.c, tx39/include/tx3904.h:
Cosmetics.
* clock/ckinit.c, clock/clock.h, mongoosev/duart/mg5uart.c,
mongoosev/duart/mg5uart.h, mongoosev/duart/mg5uart_reg.c,
mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/vectorisrs.c,
shared/interrupts/vectorexceptions.c, timer/timer.c,
tx39/include/tx3904.h: Convert to using c99 fixed size types.
* clock/ckinit.c, mongoosev/duart/mg5uart.c, mongoosev/duart/mg5uart.h,
mongoosev/duart/mg5uart_reg.c, mongoosev/include/mongoose-v.h,
mongoosev/vectorisrs/maxvectors.c, mongoosev/vectorisrs/vectorisrs.c,
r46xx/vectorisrs/maxvectors.c, shared/interrupts/isr_entries.S,
timer/timer.c, tx39/vectorisrs/maxvectors.c: URL for license changed.
* mongoosev/Makefile.am: Merge-in mongoosev/include/Makefile.am.
Install include/mongoose-v.h.
* mongoosev/include/Makefile.am: Remove.
* mongoosev/duart/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* r46xx/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/interrupts/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/include/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/Makefile.am: Remove AUTOMAKE_OPTIONS.
* tx39/vectorisrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mongoosev/include/mongoose-v.h: Added cache constants.
* mongoosev/vectorisrs/vectorisrs.c: More tinkering to improve
performance.
* Lots of tinkering and tuning as part of improving interrupt latency
and improving the per-task interrupt level control and FP mask handling.
With these modifications interrupt latency was measured at a worst-case
of 100us, average below 60 us on a 12 Mhz R3000 class CPU with 50
RTEMS tasks in the application.
* mongoosev/README: Updated.
* mongoosev/include/mongoose-v.h: Masks modified.
* mongoosev/vectorisrs/vectorisrs.c: Significant overhaul to address
software prioritization of interrupts. If a higher priority interrupt
occurs while we are looking for new interrupts, we will reinitiate the
scan of all interrupts.
* shared/interrupts/vectorexceptions.c: Removed warning and deleted
blank lines.
* tx39/include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* mongoosev/include/Makefile.am: Use 'TMPINSTALL_FILES ='.
* mongoosev/duart/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/cache/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/cache/Makefile.am: Use 'CLEANFILES ='.
* mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/vectorisrs.c,
r46xx/vectorisrs/vectorisrs.c, tx39/vectorisrs/vectorisrs.c,
tx39/include/tx3904.h: All exceptions were given low numbers and thus
can be now be installed and processed in a uniform manner just like interrupts.
Variances between various MIPS ISA levels are not accounted for at this time.
* mongoosev/vectorisrs/Makefile.am, mongoosev/vectorisrs/maxvectors.c,
r46xx/vectorisrs/Makefile.am, r46xx/vectorisrs/maxvectors.c,
tx39/vectorisrs/Makefile.am, tx39/vectorisrs/maxvectors.c,
shared/interrupts/maxvectors.c, shared/interrupts/Makefile.am: Split the
shared maxvectors.c into a variety of CPU model specific versions to simplify
the build process and reduce depdencies. Deleted shared/interrupts/maxvectors.c
and created various CPU model versions.
* Assisted in design and debug by Joel Sherrill <joel@OARcorp.com>.
* mongoosev/duart/mg5uart.c, mongoosev/duart/mg5uart.h,
shared/interrupts/maxvectors.c: Now works. Significant rework
of exceptions and interrupt vectoring to clean things up.
* shared/interrupts/vectorexceptions.c: Removed.
* shared/interrupts/Makefile.am: Reflects above.
* mongoosev/duart/mg5uart.c (mg5uart_enable_interrupts): Honor
the other bits set in the Peripheral Function Interrupt Mask
Register when modifying those enabled for the DUART.
* mongoosev/include/mongoose-v.h (MONGOOSEV_ATOMIC_MASK,
MONGOOSEV_PFICR, MONGOOSEV_PFIMR, mongoosev_set_in_pficr,
mongoosev_clear_in_pficr, mongoosev_set_in_pfimr,
mongoosev_clear_in_pfimr, MONGOOSEV_UART_ALL_IRQ_BITS): New macros.
* Added mongoose-v, mongoose-v/include, and mongoose-v/vectorisrs
directories.
* mongoosev/.cvsignore, mongoosev/Makefile.am, mongoosev/README,
mongoosev/duart/.cvsignore, mongoosev/duart/Makefile.am,
mongoosev/duart/README.mguart, mongoosev/duart/mg5uart.c,
mongoosev/include/.cvsignore, mongoosev/include/Makefile.am,
mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/.cvsignore,
mongoosev/vectorisrs/Makefile.am, mongoosev/vectorisrs/vectorisrs.c:
New files.
* Makefile.am, configure.in, shared/interrupts/Makefile.am,
shared/interrupts/maxvectors.c: Added support for mongoosev.
* tx39/vectorisrs/vectorisrs.c: Corrected warning.
