* | Remove libcpu/mips/clock - unused code | Joel Sherrill | 2014-10-13 | 1 | -23/+0 |
| | | | | | | | | | This code was only referenced for r46xx CPU models. There are no BSPs currently in the tree with this CPU model. The r46xx was the original target for the MIPS port and it is likely that the code has not been used on actual hardware in many years. All MIPS BSPs successfully built after this was removed. | ||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 1 | -1/+1 |
| | | | | | | | | * clock/ckinit.c, clock/clock.h, mongoosev/duart/mg5uart.c, mongoosev/duart/mg5uart.h, mongoosev/duart/mg5uart_reg.c, mongoosev/include/mongoose-v.h, mongoosev/vectorisrs/vectorisrs.c, shared/interrupts/vectorexceptions.c, timer/timer.c, tx39/include/tx3904.h: Convert to using c99 fixed size types. | ||||
* | added $ string to file header | Joel Sherrill | 1996-09-11 | 1 | -0/+1 |
* | new file for MIPS port by Craig Lebakken (lebakken@minn.net) and | Joel Sherrill | 1996-09-06 | 1 | -0/+24 |
Derrick Ostertag (ostertag@transition.com). |
