* | Unused. | Ralf Corsepius | 2004-03-08 | 1 | -2/+0 |
* | 2002-08-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-05 | 1 | -0/+2 |
* Per PR260 eliminate use of make-target-options. This impacted RTEMS allowing a distinction between the CPU32 and CPU32+ in the SuperCore and required that the m68k optimized memcpy be moved to libcpu. * shared/misc/memcpy.c: Moved from score/cpu/m68k. * configure.ac, shared/Makefile.am: Modified to reflect new directory. * shared/misc/.cvsignore, shared/misc/Makefile.am: New file. |
