Update #3285.
output.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* mcf5206/timer/timerisr.S: Make compile again.
* mcf5206/timer/timerisr.S: Remove unnecessary include of bsp.h
* arm/at91rm9200/timer/timer.c, arm/lpc22xx/timer/timer.c,
arm/mc9328mxl/timer/timer.c, arm/s3c2400/timer/timer.c,
arm/s3c24xx/timer/timer.c, bfin/timer/timer.c,
m68k/mcf5206/timer/timer.c, m68k/mcf5272/timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
* mcf5206/timer/timer.c, mcf5206/timer/timerisr.S,
mcf5272/timer/timer.c, mcf5272/timer/timerisr.S: Rename timer driver
* m68040/fpsp/rtems_fpsp.c, mcf5206/clock/ckinit.c,
mcf5206/console/mcfuart.c, mcf5206/include/mcf5206e.h,
mcf5206/include/mcfmbus.h, mcf5206/include/mcfuart.h,
mcf5206/mbus/mcfmbus.c, mcf5206/timer/timer.c: Convert to using c99
fixed size types.
* configure.ac: Cosmetics.
* clock/Makefile.am: Remove.
* console/Makefile.am: Remove.
* mbus/Makefile.am: Remove.
* timer/Makefile.am: Remove.
* Makefile.am: Merge-in former clock/Makefile.am, console/Makefile.am,
include/Makefile.am, mbus/Makefile.am, timer/Makefile.am.
* mbus/Makefile.am: Cosmetics.
* Makefile.am: Reformat.
* clock/Makefile.am: Reformat.
* console/Makefile.am: Reformat.
* include/Makefile.am: Reformat. Use dirstamps for preinstallation.
* timer/Makefile.am: Reformat.
* clock/ckinit.c, console/mcfuart.c, include/mcf5206e.h,
include/mcfmbus.h, include/mcfuart.h, mbus/mcfmbus.c, timer/timer.c,
timer/timerisr.S: URL for license changed.
* clock/ckinit.c, console/mcfuart.c, timer/timer.c, timer/timerisr.S:
Correct copyright statements.
m68040/Makefile.am: Reflect having moved automake.
m68040/fpsp/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/cache/Makefile.am: Reflect having moved automake.
shared/misc/Makefile.am: Reflect having moved automake.
* clock/Makefile.am: Eliminate *_O_FILES.
Don't include @RTEMS_BSP@.cfg.
* console/Makefile.am: Likewise.
* mbus/Makefile.am: Likewise.
* timer/Makefile.am: Likewise.
* m68040/fpsp/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/console/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/mbus/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/cache/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/misc/Makefile.am: Use .$(OBJEXT) instead of .o.
* mbus/Makefile.am: Remove AUTOMAKE_OPTIONS.
* New libcpu support for mcf5206e.
* ChangeLog, clock/ckinit.c, clock/.cvsignore, configure.ac,
console/mcfuart.c, console/.cvsignore, include/mcf5206e.h,
include/mcfmbus.h, include/mcfuart.h, include/.cvsignore,
mbus/mcfmbus.c, mbus/.cvsignore, timer/timer.c, timer/timerisr.S,
timer/.cvsignore, .cvsignore: New files.
