Update #3285.
Update #3285.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* m68040/fpsp/rtems_fpsp.c: Move extern outside of braces.
* m68040/fpsp/rtems_skel.S: Include <rtems/asm.h> instead of <asm.h>.
* m68040/fpsp/rtems_fpsp.c, mcf5206/clock/ckinit.c,
mcf5206/console/mcfuart.c, mcf5206/include/mcf5206e.h,
mcf5206/include/mcfmbus.h, mcf5206/include/mcfuart.h,
mcf5206/mbus/mcfmbus.c, mcf5206/timer/timer.c: Convert to using c99
fixed size types.
* m68040/Makefile.am: Merge-in m68040/fpsp/Makefile.am.
Use automake-compilation rules.
* m68040/fpsp/Makefile.am: Remove.
* shared/Makefile.am: Use automake compilation rules.
* Makefile.am: Reflect changes above. Remove CPU_SUBDIR.
* configure.ac: Require automake >= 1.8.2.
Add subdir-objects to AUTOMAKE_OPTIONS.
Remove CHECK_CUSTOM_BSP.
* m68040/fpsp/Makefile.am: Remove all-local: $(ARCH).
* shared/cache/Makefile.am: Remove all-local: $(ARCH).
* shared/misc/Makefile.am: Remove all-local: $(ARCH).
* m68040/Makefile.am: Reformat.
* m68040/fpsp/Makefile.am: Reformat.
* shared/Makefile.am: Reformat.
* shared/cache/Makefile.am: Reformat. Use dirstamps for preinstallation.
* shared/misc/Makefile.am: Reformat.
m68040/Makefile.am: Reflect having moved automake.
m68040/fpsp/Makefile.am: Reflect having moved automake.
shared/Makefile.am: Reflect having moved automake.
shared/cache/Makefile.am: Reflect having moved automake.
shared/misc/Makefile.am: Reflect having moved automake.
* m68040/fpsp/Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* shared/cache/Makefile.am: Ditto.
* shared/misc/Makefile.am: Ditto.
* m68040/fpsp/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/clock/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/console/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/mbus/Makefile.am: Use .$(OBJEXT) instead of .o.
* mcf5206/timer/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/cache/Makefile.am: Use .$(OBJEXT) instead of .o.
* shared/misc/Makefile.am: Use .$(OBJEXT) instead of .o.
* m68040/fpsp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* m68040/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/cache/Makefile.am: Remove AUTOMAKE_OPTIONS.
* shared/Makefile.am: Remove AUTOMAKE_OPTIONS.
* m68040/fpsp/Makefile.am, shared/cache/Makefile.am:
* m68040/fpsp/Makefile.am, shared/cache/Makefile.am: Include
compile.am
converted to automake.
esp. some powerpc cpu-models
them to $(PROJECT_INCLUDE)/
./bootstrap
BSP needs to be eliminated.
to address m68k-rtemself for the MVME167.
Here is the rtems patch I promissed you a long time ago to enable ELF
with m68k. The target name I selected is m68k-rtemself. It preserves the
m68k-rtems COFF target, and is parterned after the other ELF/COFF dual
targets.
The mvme167.cfg file causes the -qelf flag to be used during compilation
if the name of the compiler contains rtemself. This flag is used in the
bsp_specs file to select the elflinkcmds file rather than the linkcmds
file. The former is for ELF, the latter for COFF.
Some patches are required to the mc68040 FPSP code. Some of the
assembler files contain instructions that were rejected by the
m68k-rtemself-as assembler. This is a minor bug in the m68k ELF
assembler, I think.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
enclose.
were a number of minor problems which had to be fixed to get it
to compile including modifying the compile rule to handle C++ comments,
changing the syntax of the include statement, and getting rid of "%"
as part of register names.
to RTEMS by Eric Norum. It is freely distributable and was acquired
from the Motorola WWW site. More info is in the FPSP README.
