* README: i960 obsoleted.
* i960/.cvsignore, i960/ChangeLog, i960/Makefile.am, i960/configure.ac,
i960/i960ca/.cvsignore, i960/i960ca/Makefile.am,
i960/i960ca/cpu_install_intr_stack.c,
i960/i960ca/cpu_install_raw_isr.c, i960/i960ka/.cvsignore,
i960/i960ka/Makefile.am, i960/i960ka/cpu_install_intr_stack.c,
i960/i960ka/cpu_install_raw_isr.c, i960/i960rp/.cvsignore,
i960/i960rp/Makefile.am, i960/i960rp/cpu_install_intr_stack.c,
i960/i960rp/cpu_install_raw_isr.c, i960/include/i960CA.h,
i960/include/i960HA.h, i960/include/i960JX_RP_common.h,
i960/include/i960KA.h, i960/include/i960RP.h: Removed.
* i960rp/cpu_install_intr_stack.c: Cosmetics.
* i960ca/cpu_install_intr_stack.c, i960ca/cpu_install_raw_isr.c,
i960ka/cpu_install_intr_stack.c, i960ka/cpu_install_raw_isr.c,
i960rp/cpu_install_intr_stack.c, i960rp/cpu_install_raw_isr.c:
Convert to using c99 fixed size types.
* configure.ac: Add 2nd argument (rtems_updir) to RTEMS_TOP.
* i960ca/Makefile.am, i960ka/Makefile.am, i960rp/Makefile.am: Don't
include .../lib.am.
Use automake compilation rules.
* configure.ac: Add subdir-objects to AUTOMAKE_OPTIONS.
Require automake >= 1.8.2.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* i960ca/Makefile.am: Remove all-local: $(ARCH).
* i960ka/Makefile.am: Remove all-local: $(ARCH).
* i960rp/Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Use dirstamps for preinstallation.
* i960ca/Makefile.am: Reformat.
* i960ka/Makefile.am: Reformat.
* i960rp/Makefile.am: Reformat.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
i960ca/Makefile.am: Reflect having moved automake.
i960ka/Makefile.am: Reflect having moved automake.
i960rp/Makefile.am: Reflect having moved automake.
* include/Makefile.am: Removed.
* Makefile.am: Remove CPU_MODEL_SUBDIR.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP).
* i960ca/Makefile.am: Eliminate *_O_FILES.
Don't include @RTEMS_BSP@.cfg.
* i960ka/Makefile.am: Ditto.
* i960rp/Makefile.am: Ditto.
* shared/soft_reset_asm.S: Removed.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* i960ca/Makefile.am: Use .$(OBJEXT) instead of .o.
* i960ka/Makefile.am: Use .$(OBJEXT) instead of .o.
* i960rp/Makefile.am: Use .$(OBJEXT) instead of .o.
* include/i960CA.h, include/i960RP.h: Correct inline assembly
forward reference labels.
* i960ca/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i960ka/Makefile.am: Remove AUTOMAKE_OPTIONS.
* i960rp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
Remove H_FILES.
* include/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* Makefile.am: Corrected condition CPU model selection so
multilib'ing and bare BSP works.
Include compile.am
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
are now in libcpu. This required significant rework of the
score/cpu header files and the creation of multiple header files
and subdirectories in libcpu/i960.
