* Makefile.am: Don't include .../lib.am.
PR 557/bsps
* cpu.c: Removed. File appears to have been orphaned around June 2000
* Makefile.am: Split the blob of *.o into cache.rel, page.rel and
score.rel. Add PREINSTALL_DIRS.
Use automake compilation rules.
* page.c, cpuModel.S: Remove stray blanks.
* configure.ac: Require automake >= 1.8.2.
Add AM_PROG_CC_C_O. Add subdir-objects to AUTOMAKE_OPTIONS.
* Makefile.am: Eliminate VPATH.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Reformat. Use dirstamps for preinstallation.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CPU.
* cpu.c, cpu.h, cpuModel.S, cpuModel.h, displayCpu.c, idtr.S, page.c:
URL for license changed.
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* configure.ac: Add RTEMS_PROG_CCAS.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* cpuModel.S: Include <rtems/score/registers.h> instead of
<libcpu/registers.h>.
* registers.h: Removed.
* Makefile.am: Remove registers.h.
* cache.c: Include <rtems/score/registers.h> instead of
* cpu.h: Ditto. Remove parts moved to score/cpu/i386.
* registers.h: Add BIG-FAT warning.
* cpuModel.h: PR 146.
Adding guards. Remove unnecessary headers.
* i386/displayCpu.c: Include rtems/bspIo.h instead of bspIo.h.
* i386/page.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.in: Remove.
* Makefile.am: Use 'CLEANFILES ='.
* Makefile.am: Apply include_*HEADERS instead of H_FILES.
* .cvsignore: Add cache.h.
* displayCpu.c: Added include of <rtems.h> to eliminate warnings.
* page.c: Readd deleted comment lines.
* page.c: Replaced prototype of printk() with include of <bspIo.h>.
* idt.c, Makefile.am: Moved idt.c to libbsp/i386/shared so
i386 RTEMS can be multilib'ed.
* Makefile.am: Include compile.am
routine naming to follow RTEMS package/object.method rule.
This patch also eliminated calls to the obsolete routine
m68k_enable_caching.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
