* Makefile.am: Don't include @RTEMS_BSP@.cfg.
Eliminate *_O_FILES.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* configure.ac: Add RTEMS_PROG_CCAS.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* cpuModel.S: Include <rtems/score/registers.h> instead of
<libcpu/registers.h>.
* registers.h: Removed.
* Makefile.am: Remove registers.h.
* cache.c: Include <rtems/score/registers.h> instead of
* cpu.h: Ditto. Remove parts moved to score/cpu/i386.
* registers.h: Add BIG-FAT warning.
* cpuModel.h: PR 146.
Adding guards. Remove unnecessary headers.
* i386/displayCpu.c: Include rtems/bspIo.h instead of bspIo.h.
* i386/page.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.in: Remove.
* Makefile.am: Use 'CLEANFILES ='.
* Makefile.am: Apply include_*HEADERS instead of H_FILES.
* .cvsignore: Add cache.h.
* displayCpu.c: Added include of <rtems.h> to eliminate warnings.
* page.c: Readd deleted comment lines.
* page.c: Replaced prototype of printk() with include of <bspIo.h>.
* idt.c, Makefile.am: Moved idt.c to libbsp/i386/shared so
i386 RTEMS can be multilib'ed.
* Makefile.am: Include compile.am
routine naming to follow RTEMS package/object.method rule.
This patch also eliminated calls to the obsolete routine
m68k_enable_caching.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
converted to automake.
esp. some powerpc cpu-models
them to $(PROJECT_INCLUDE)/
./bootstrap
./bootstrap
dependencies of "Makefile".
--enable-maintainer-mode.
warning.
future.
cd <rtems-source-tree>
Ian Lance Taylor <ian@airs.com> to note that condition codes
are modified.
issues.
egcs/contrib/egcs_update).
ATTENTION:
* "make RTEMS_BSP=<bsp> dist"
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
patch.
