line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* cache.c, cpu.h, cpuModel.h:
* cpuModel.S, cpuModel.h, displayCpu.c: Update to include more reserved
bits and pick out a bit more information.
* cpuModel.S, cpuModel.h, displayCpu.c: Save/cache CPUID:ECX
(extended capabilities) in a new variable (x86_capability_x).
Added more known flag description strings (printCpuInfo())
and let 'printCpuInfo()' dump the extended feature flags, too.
Michael South <msouth@msouth.org>
PR 1344/bsps
* cpuModel.h: Add use of TSC for nanoseconds granularity. i8254 is very
slow on some systems. TSC use is auto-detected by default.
* cpu.c, cpu.h, cpuModel.S, cpuModel.h, displayCpu.c, idtr.S, page.c:
URL for license changed.
* cpuModel.h: PR 146.
Adding guards. Remove unnecessary headers.
inline with the new IRQ structure.
Enabled on the pc386.
