* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -4/+0 |
* | Remove all-local:. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Cleanup. | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | Add preinstall.am | Ralf Corsepius | 2005-11-04 | 1 | -23/+6 |
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 1 | -3/+3 |
| | | | | * Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-03 | 1 | -1/+1 |
| | | | | * Makefile.am: Fix typo. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 1 | -33/+4 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-06 | 1 | -1/+0 |
| | | | | * Makefile.am: Don't include .../lib.am. | ||||
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 1 | -18/+48 |
| | | | | | | | | | * Makefile.am: Split the blob of *.o into cache.rel, page.rel and score.rel. Add PREINSTALL_DIRS. Use automake compilation rules. * page.c, cpuModel.S: Remove stray blanks. * configure.ac: Require automake >= 1.8.2. Add AM_PROG_CC_C_O. Add subdir-objects to AUTOMAKE_OPTIONS. | ||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 1 | -0/+3 |
| | | | | | * Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. | ||||
* | 2003-12-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-16 | 1 | -12/+12 |
| | | | | * Makefile.am: Eliminate VPATH. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -2/+1 |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | ||||
* | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-02 | 1 | -1/+1 |
| | | | | * Makefile.am: Remove all-local: $(ARCH). | ||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -10/+21 |
| | | | | * Makefile.am: Reformat. Use dirstamps for preinstallation. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 1 | -1/+1 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -3/+3 |
| | | | | Makefile.am: Reflect having moved automake. | ||||
* | 2002-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-19 | 1 | -5/+2 |
| | | | | | | * Makefile.am: Don't include @RTEMS_BSP@.cfg. Eliminate *_O_FILES. * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. | ||||
* | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-11 | 1 | -2/+2 |
| | | | | * Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-07-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-30 | 1 | -1/+1 |
| | | | | | | | * cpuModel.S: Include <rtems/score/registers.h> instead of <libcpu/registers.h>. * registers.h: Removed. * Makefile.am: Remove registers.h. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-09-27 | 1 | -2/+2 |
| | | | | | * Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'CLEANFILES ='. | ||||
* | 2001-02-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-03-01 | 1 | -6/+9 |
| | | | | | * Makefile.am: Apply include_*HEADERS instead of H_FILES. * .cvsignore: Add cache.h. | ||||
* | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-09 | 1 | -1/+1 |
| | | | | * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | ||||
* | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-11-02 | 1 | -1/+1 |
| | | | | * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. | ||||
* | 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-26 | 1 | -1/+1 |
| | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. | ||||
* | 2000-10-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-10-17 | 1 | -2/+1 |
| | | | | | * idt.c, Makefile.am: Moved idt.c to libbsp/i386/shared so i386 RTEMS can be multilib'ed. | ||||
* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-05 | 1 | -3/+5 |
| | | | | * Makefile.am: Include compile.am | ||||
* | Moved i386 and m68k cache management code to libcpu. Everything | Joel Sherrill | 2000-06-13 | 1 | -16/+12 |
| | | | | | | now is an implementation of the prototypes in rtems/rtems/cache.h. The libcpu/i386/wrapup directory is no longer needed. The PowerPC needs this done to it. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -2/+2 |
* | Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff from | Joel Sherrill | 2000-01-31 | 1 | -14/+12 |
| | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams | ||||
* | Removing Makefile.in and adding Makefile.am. These were missed in conversion | Joel Sherrill | 1999-12-21 | 1 | -0/+50 |
to automake by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. |
