* | bsp/bfin: Move libcpu content to bsps | Sebastian Huber | 2018-03-26 | 1 | -81/+0 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | score: Add and use Thread_Control::is_idle | Sebastian Huber | 2016-11-09 | 1 | -5/+1 |
| | | | | Update #2797. | ||||
* | libcpu/bfin/clock/clock.c: Fix warning by including <rtems/clockdrv.h> | Joel Sherrill | 2016-03-27 | 1 | -0/+2 |
* | score: Introduce Thread_Entry_information | Sebastian Huber | 2016-01-11 | 1 | -2/+2 |
| | | | | | | | This avoids potential dead code in _Thread_Handler(). It gets rid of the dangerous function pointer casts. Update #2514. | ||||
* | score: Simplify <rtems/system.h> | Sebastian Huber | 2015-06-26 | 1 | -0/+1 |
| | | | | | Drop the <rtems/score/percpu.h> include since this file exposes a lot of implementation details. | ||||
* | bfin libcpu and libbsp: Fix warnings | Joel Sherrill | 2014-10-16 | 1 | -1/+1 |
* | libcpu/bfin/clock: Fix warnings | Joel Sherrill | 2014-10-13 | 1 | -40/+11 |
* | bsps: Fix clock driver defines | Sebastian Huber | 2013-08-14 | 1 | -2/+2 |
* | score: Remove idle field of Per_CPU_Control | Sebastian Huber | 2013-05-31 | 1 | -2/+5 |
| | | | | | | This field is unused except for special case simulator clock drivers. In these places use an alternative. Add and use _Thread_Set_global_exit_status() and _Thread_Get_global_exit_status(). | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -2/+2 |
* | 2008-09-25 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 2008-09-25 | 1 | -0/+3 |
| | | | | * clock/clock.c, include/bf533.h, include/bf537.h, include/sicRegs.h: | ||||
* | 2008-09-05 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-09-05 | 1 | -43/+0 |
| | | | | | | | * clock/clock.c: The Shared Memory Driver no longer requires the special IOCTL in Clock_control. This was a hack which has existed since before the Classic API Timer Manager was implemented. All implementations of and references to Clock_control were removed. | ||||
* | 2008-08-15 Allan Hessenflow <allanh@kallisti.com> | Joel Sherrill | 2008-08-15 | 1 | -0/+150 |
* ChangeLog, Makefile.am, README, configure.ac, preinstall.am, cache/cache.c, cache/cache_.h, clock/clock.c, clock/rtc.c, clock/tod.h, include/bf533.h, include/bf537.h, include/cecRegs.h, include/coreTimerRegs.h, include/dmaRegs.h, include/ebiuRegs.h, include/ethernetRegs.h, include/gpioRegs.h, include/memoryRegs.h, include/mmuRegs.h, include/ppiRegs.h, include/rtcRegs.h, include/sicRegs.h, include/spiRegs.h, include/sportRegs.h, include/timerRegs.h, include/twiRegs.h, include/uartRegs.h, include/wdogRegs.h, interrupt/interrupt.c, interrupt/interrupt.h, mmu/mmu.c, mmu/mmu.h, network/ethernet.c, network/ethernet.h, serial/spi.c, serial/spi.h, serial/sport.c, serial/sport.h, serial/twi.c, serial/twi.h, serial/uart.c, serial/uart.h, timer/timer.c: New files. |
