* | 2002-05-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-05-17 | 1 | -75/+0 |
| | | | | * configure.ac: Remove lib. | ||||
* | 2001-08-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-08-03 | 1 | -0/+8 |
| | | | | | | * libc/libio_sockets.c (rtems_bsdnet_fdToSocket): Per bug report from Gene Smith <Gene.Smith@sea.siemens.com>, enhanced the error checking to account for a socket being closed. | ||||
* | 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-08 | 1 | -0/+4 |
| | | | | | | | * configure.in: Add libc/config.h * libc/Makefile.am: Add INCLUDES += -I. to pickup config.h * libc/.cvsignore: Add config.h and stamp-h * libc/*.c: Add config.h support. | ||||
* | 2000-11-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-11-01 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am, include/rtems/libio_.h, libc/Makefile.am, libc/assoc.c, libc/assocnamebad.c, libc/base_fs.c, libc/cfsetispeed.c, libc/cfsetospeed.c, libc/chdir.c, libc/chmod.c, libc/chown.c, libc/close.c, libc/closedir.c, libc/dup2.c, libc/error.c, libc/eval.c, libc/fchdir.c, libc/fchmod.c, libc/fcntl.c, libc/fdatasync.c, libc/fpathconf.c, libc/fstat.c, libc/fsync.c, libc/ftruncate.c, libc/getdents.c, libc/ioctl.c, libc/libio.c, libc/libio_sockets.c, libc/link.c, libc/lseek.c, libc/malloc.c, libc/mallocfreespace.c, libc/mknod.c, libc/mount.c, libc/newlibc.c, libc/no_libc.c, libc/open.c, libc/read.c, libc/readlink.c, libc/rmdir.c, libc/stat.c, libc/symlink.c, libc/tcsetattr.c, libc/telldir.c, libc/ttyname.c, libc/ttyname_r.c, libc/umask.c, libc/unlink.c, libc/unmount.c, libc/utime.c, libc/write.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. * include/rtems/Makefile.am, include/rtems/.cvsignore: New file. * include/rtems/assoc.h, include/rtems/error.h, include/rtems/libcsupport.h, include/rtems/libio.h, include/rtems/libio_.h: New/moved files. | ||||
* | Removed warning for const removal. | Joel Sherrill | 1999-03-30 | 1 | -1/+1 |
* | Patch from Eric Norum <eric@skatter.usask.ca> to eliminate external | Joel Sherrill | 1999-03-01 | 1 | -8/+14 |
| | | | | | IO handlers scheme that was implemented originally just to support sockets. The file system IO switch is more general and works fine. | ||||
* | Patch from Eric Norum <eric@skatter.usask.ca> to set more flags in | Joel Sherrill | 1999-01-28 | 1 | -2/+2 |
| | | | | rtems_bsdnet_makeFdForSocket(). | ||||
* | Added libio_sockets.c to hold support routines for networking code. | Joel Sherrill | 1999-01-26 | 1 | -0/+58 |
