* | 2000-10-18 Chris Johns <ccj@acm.org> | Joel Sherrill | 2000-10-18 | 1 | -37/+0 |
| | | | | | | | | | | | | | | | | | * libfs created. * libc/deviceio.c, libc/imfs_getchild.c, libc/imfs_readlink.c, libc/imfs.h, libc/imfs_gtkn.c, libc/imfs_rmnod.c, libc/imfs_chown.c, libc/imfs_handlers_device.c, libc/imfs_stat.c, libc/imfs_creat.c, libc/imfs_handlers_directory.c, libc/imfs_symlink.c, libc/imfs_debug.c, libc/imfs_handlers_link.c, libc/imfs_unixstub.c, libc/imfs_directory.c, libc/imfs_handlers_memfile.c, libc/imfs_unlink.c, libc/imfs_eval.c, libc/imfs_init.c, libc/imfs_unmount.c, libc/imfs_fchmod.c, libc/imfs_initsupp.c, libc/imfs_utime.c, libc/imfs_fcntl.c, libc/imfs_link.c, libc/memfile.c, libc/imfs_fdatasync.c, libc/imfs_mknod.c, libc/miniimfs_init.c, libc/imfs_free.c, libc/imfs_mount.c, libc/imfs_fsunmount.c, libc/imfs_ntype.c: Moved to libfs/src/imfs. * Makefile.am: Modified to reflect above. | ||||
* | Unmount was failing as a side-effect of splitting the rmnod handler | Joel Sherrill | 1999-11-05 | 1 | -1/+1 |
| | | | | and not handling every case properly. | ||||
* | The object memfile.o was being included in the miniIMFS even though it | Joel Sherrill | 1999-11-02 | 1 | -1/+1 |
| | | | | | | | should not have been. This required that IMFS_rmnod be split into three separate (per file type) routines to avoid dependencies. In the end, a miniIMFS application is 6K smaller than one using the full IMFS. | ||||
* | Moved the rmnod callback from the operations table to the handler table. | Jennifer Averett | 1999-10-29 | 1 | -1/+2 |
* | New files created by split of old imfs_handlers.c. | Joel Sherrill | 1999-10-26 | 1 | -0/+37 |
