* | 2000-10-18 Chris Johns <ccj@acm.org> | Joel Sherrill | 2000-10-18 | 1 | -129/+0 |
| | | | | | | | | | | | | | | | | | * libfs created. * libc/deviceio.c, libc/imfs_getchild.c, libc/imfs_readlink.c, libc/imfs.h, libc/imfs_gtkn.c, libc/imfs_rmnod.c, libc/imfs_chown.c, libc/imfs_handlers_device.c, libc/imfs_stat.c, libc/imfs_creat.c, libc/imfs_handlers_directory.c, libc/imfs_symlink.c, libc/imfs_debug.c, libc/imfs_handlers_link.c, libc/imfs_unixstub.c, libc/imfs_directory.c, libc/imfs_handlers_memfile.c, libc/imfs_unlink.c, libc/imfs_eval.c, libc/imfs_init.c, libc/imfs_unmount.c, libc/imfs_fchmod.c, libc/imfs_initsupp.c, libc/imfs_utime.c, libc/imfs_fcntl.c, libc/imfs_link.c, libc/memfile.c, libc/imfs_fdatasync.c, libc/imfs_mknod.c, libc/miniimfs_init.c, libc/imfs_free.c, libc/imfs_mount.c, libc/imfs_fsunmount.c, libc/imfs_ntype.c: Moved to libfs/src/imfs. * Makefile.am: Modified to reflect above. | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 1 | -3/+3 |
* | Changed IMFS to use IMFS_NAME_MAX as the maximum length of a basename | Joel Sherrill | 1999-02-24 | 1 | -1/+1 |
| | | | | | | | rather then NAME_MAX. NAME_MAX is 255 and that lets IMFS chew up memory too fast. Perhaps in the future, the places in IMFS that put a maximum length name string on the stack and the jnode structure does not include a maximu length name string can be fixed so this is not a problem. | ||||
* | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1998-11-23 | 1 | -0/+130 |
overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. |
