path: root/c/src/lib/libc/TODO (follow)
* 2002-05-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-171-14/+0
| | | | * configure.ac: Remove lib.
* Patch from Chris Johns <cjohns@cybertec.com.au> to add fchdir()Joel Sherrill2000-06-301-0/+3
| | | | functionality to libc and update TODO.
* Added base version of file system infrastructure. This includes a majorJoel Sherrill1998-11-231-0/+11
