* | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 1999-11-04 | 11 | -8/+607 |
| | | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | ||||
* | Typo fixed by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 1999-11-03 | 1 | -1/+1 |
* | Split console_reserve_resources into its own file to reduce dependencies. | Joel Sherrill | 1999-11-02 | 3 | -10/+30 |
| | | | | Still need to move debug io routines out. | ||||
* | Removed all references to shared memory driver as it is not supported | Joel Sherrill | 1999-11-01 | 1 | -5/+0 |
| | | | | yet on the mvme2307. | ||||
* | Removed shmsupp directory as it is not really implemented. | Joel Sherrill | 1999-11-01 | 1 | -6/+1 |
* | MVME2307 does not really include MP support. | Joel Sherrill | 1999-11-01 | 5 | -311/+0 |
* | Patch rtems-rc-19991011-3.diff from Ralf Corsepius. | Joel Sherrill | 1999-10-28 | 2 | -2/+33 |
* | Notes on what to do when merging a BSP. | Joel Sherrill | 1999-10-28 | 1 | -0/+73 |
* | Patch from Aleksey (Quality Quorum <qqi@world.std.com>) to | Joel Sherrill | 1999-10-27 | 2 | -19/+36 |
| | | | | | | increase ease of application configuration of the pc386 BSP. This patch allows switching the printk console to a serial port and overriding bsp_start by making it a weak alias. | ||||
* | Added $(EXEEXT) in attempt to help Cygwin install process. | Joel Sherrill | 1999-10-27 | 1 | -2/+2 |
* | Last cleanup to attempt to link. | Joel Sherrill | 1999-10-27 | 2 | -1/+3 |
* | rxgen960 now compiles -- may not link. | Joel Sherrill | 1999-10-27 | 11 | -42/+32 |
* | Added CVS Ids and a basic header. More header cleanup needed. | Joel Sherrill | 1999-10-27 | 42 | -9/+174 |
* | Removed systbl.S save_systbl.c. They were unnecessary. | Joel Sherrill | 1999-10-27 | 3 | -523/+2 |
* | Removed sctns.S. This file was obviously the output of the compiler. | Joel Sherrill | 1999-10-27 | 2 | -336/+1 |
* | Replaced Makefile.in's with modified copies of cvme961 to get | Joel Sherrill | 1999-10-27 | 9 | -152/+242 |
| | | | | autoconf/automake changes. | ||||
* | Moved timerisr.s to timerisr.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved systbl.s to systbl.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved sctns.s to sctns.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved rxgen_romld.s to rxgen_romld.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved ihandler.s to ihandler.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved asmstub.s to asmstub.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | Moved asmfault.s to asmfault.S per GNU conventions. | Joel Sherrill | 1999-10-27 | 1 | -0/+0 |
* | The rxgen960 BSP and i960 RPM support was submitted by Mark Bronson | Joel Sherrill | 1999-10-27 | 71 | -0/+6584 |
| | | | | <mark@ramix.com> of RAMIX. | ||||
* | Split console_reserve_resources to separate file to reduce | Joel Sherrill | 1999-10-26 | 3 | -7/+42 |
| | | | | code size. | ||||
* | Patch from Emmanuel Raguet <raguet@crf.canon.fr> to fix a small bug where | Joel Sherrill | 1999-10-26 | 1 | -1/+1 |
| | | | | the receive buffer size was 16 bytes too small. | ||||
* | Modifications from Erik Ivanenko <erik.ivanenko@utoronto.ca> to add | Joel Sherrill | 1999-10-26 | 2 | -5/+17 |
| | | | | | proper Multiboot signature to pc386 BSP. This enables Grub to recognize the image. | ||||
* | Patch from Erik Ivanenko <erik.ivanenko@utoronto.ca> to fix some | Joel Sherrill | 1999-10-26 | 1 | -28/+68 |
| | | | | reported bugs in the start code. | ||||
* | tch from Eric Valette <valette@crf.canon.fr> and Emmanuel Raguet | Joel Sherrill | 1999-10-25 | 2 | -72/+72 |
| | | | | | <raguet@crf.canon.fr> to fix bugs and make the mcp750 boot RTEMS running the GoAhead web server. | ||||
* | Modified to produce correct output with new version of sis. | Joel Sherrill | 1999-10-25 | 1 | -1/+6 |
* | Now compiles for coff and elf. | Joel Sherrill | 1999-10-11 | 1 | -65/+185 |
* | Removed aclocal.m4 generated from aclocal macros | Joel Sherrill | 1999-10-06 | 8 | -2910/+0 |
* | Removed configure generated from configure.in | Joel Sherrill | 1999-10-06 | 8 | -13321/+0 |
* | Modified to avoid conflicts on definitions of malloc. newlib 1.8.2 | Joel Sherrill | 1999-10-06 | 1 | -1/+1 |
| | | | | | | | | now prototypes the malloc family in stdlib.h. This causes conflicts with the way the network stack overrides the definitions of malloc. As best I (being Joel) can tell, commenting stdlib.h out keeps the files compiling and referencing the desired malloc/free but results in more warnings. | ||||
* | Modified to explicitly list all files as part of C_PIECES. | Joel Sherrill | 1999-10-06 | 1 | -1/+2 |
* | Added sections as required by C++ and ELF. | Joel Sherrill | 1999-10-06 | 4 | -3/+14 |
* | Added more sections and made minor modifications to let the linkcmds | Joel Sherrill | 1999-10-06 | 8 | -29/+54 |
| | | | | | work with m68k-elf on late model versions of binutils (990901+) without overlapping or missing section errors. | ||||
* | Added comment with CVS Id. | Joel Sherrill | 1999-10-05 | 1 | -0/+4 |
* | Changed bra.s to bra.l to remove error with new version of binutils. | Joel Sherrill | 1999-10-05 | 2 | -4/+4 |
* | Changed bra.s to bra.l to correct compilation error triggered by new | Joel Sherrill | 1999-10-05 | 2 | -2/+2 |
| | | | | version of binutils. | ||||
* | Corrected so sections did not overlap with new version of binutils. | Joel Sherrill | 1999-10-05 | 1 | -0/+6 |
* | Corrected comment. | Joel Sherrill | 1999-10-05 | 2 | -2/+2 |
* | Modified to remove reference to Force CPU386. Actually this was a misnamed | Joel Sherrill | 1999-10-05 | 1 | -2/+2 |
| | | | | conditional that should have been fixed long ago. | ||||
* | Modified to remove error for overlapping sections now that | Joel Sherrill | 1999-10-05 | 1 | -27/+19 |
| | | | | gnu.linkonce* sections are included. | ||||
* | Removed targets and configurations that are no longer functional | Joel Sherrill | 1999-10-05 | 50 | -4935/+0 |
| | | | | | | | | | | | | | | and not likely to become so. Comments on each configuration are below. + Force CPU386 - This BSP was developed as part of the initial port of RTEMS to the i386. This board has been unavailable for a long time now. + GO32 - This BSP and some CPU code supported djgpp v1.x. This version is now quite old. No one has stepped forward to update the code to v2.x which may be technically impossible anyway. More importantly, go32 has been superceded by the pc386 BSP. | ||||
* | Minor corrections to get mvme2307 to compile. | Joel Sherrill | 1999-10-05 | 12 | -24/+24 |
* | Patch from Eric Valette <valette@crf.canon.fr> with two small | Joel Sherrill | 1999-10-05 | 2 | -0/+16 |
| | | | | fixes related to GDB over TCP/IP debug. | ||||
* | Regenerated. | Joel Sherrill | 1999-10-05 | 16 | -876/+1133 |
* | Motorola MVME2307 BSP submitted by Jay Kulpinski <jskulpin@eng01.gdds.com>. | Joel Sherrill | 1999-10-04 | 38 | -0/+5142 |
| | | | | No modifications made. | ||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1999-10-04 | 9 | -32/+32 |
| | | | | where wrapup left pieces out of the librtemsall.a. |
