* | 2009-07-03 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-03 | 1 | -44/+0 |
| | | | | | * Makefile.am: Switch to shared routine. * startup/setvec.c: Removed. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 1 | -1/+1 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -2/+0 |
| | | | | | | | | * clock/clock.c, console/console.c, include/bsp.h, shmsupp/addrconv.c, shmsupp/cause_intr.c, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c, startup/exit.c, startup/setvec.c, timer/timer.c: URL for license changed. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | Updates from Tony Bennett. | Joel Sherrill | 1996-04-22 | 1 | -1/+1 |
* | all targets compile .. tony's patches in place | Joel Sherrill | 1995-09-29 | 1 | -12/+0 |
* | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1995-09-27 | 1 | -1/+0 |
| | | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | ||||
* | Added flush of output on exit. On some UNIX's using the native library | Joel Sherrill | 1995-08-11 | 1 | -3/+3 |
| | | | | | | | | | resulted in no output when the output was redirected until this was done. Redirection is important because runtest redirects test output. Added support for numerous environment variables which make it easier to run a multi-node system using a single executable and to tailor the size of the workspace and heap. | ||||
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 1 | -0/+60 |
