* | Remove (Abandoned). | Ralf Corsepius | 2009-10-14 | 1 | -29/+0 |
| | | | | | | | | * clock/clock.c, console/console.c, include/bsp.h, shmsupp/addrconv.c, shmsupp/cause_intr.c, shmsupp/getcfg.c, shmsupp/lock.c, shmsupp/mpisr.c, startup/bspclean.c, startup/bspstart.c, startup/exit.c, startup/setvec.c, timer/timer.c: URL for license changed. | ||||
* | Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h. | Joel Sherrill | 1999-11-30 | 1 | -1/+1 |
| | | | | | Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager). | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | changes remerged after lost in disk crash -- recovered from snapshot, ↵ | Joel Sherrill | 1995-12-20 | 1 | -0/+30 |
| | | | | partially recovered working tree, etc | ||||
* | changes remerged after disk crash -- history lost | Joel Sherrill | 1995-12-19 | 1 | -30/+0 |
* | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1995-09-27 | 1 | -2/+0 |
| | | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | ||||
* | Ada95, gnat, go32 | Joel Sherrill | 1995-07-12 | 1 | -0/+32 |
