that converts the unix directory to automake.
Ralf's note: Please check c/src/lib/libbsp/unix/posix/startup/Makefile.am.
I am not sure if it is correct.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
to lib/include.
be resolved.
