Update #3285.
This file is BSP-independent.
Update #3285.
The definition of _CPU_Trap_slot_template is BSP-independent. A
potential para-virtualization support may use <rtems/score/paravirt.h>.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
The
KEEP (*(SORT(.ctors.*)))
KEEP (*(.ctors))
cannot be simplified to
KEEP (*(SORT(.ctors*)))
since
.ctors < .ctors.*
in lexicographical order.
See spglobalcon02 test case.
Update #3319.
This was at the request of a user to make it easier to have a
custom entry point. This way they just provide their own top
level linkcmds and include linkcmds.base.
Updates #3520.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Updates #3520.
Add device spin-lock around internal data structures. Since the driver
provides a low-level C API accessing the descriptors the application
still needs to implement part of the SMP synchonization needed between
Interrupt handler and tasks.
Close #2355.
SMP safe by spin-lock protection and semaphore. On spin-lock per SpW/AMBA
port to allow multiple parallel register operations per port. A common
semaphore for general SpW router configuration such as routing table.
Move to a C API instead of using the I/O Manager. The SpW router driver
does not perform any I/O only management of the router.
Update #2355.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Fixes #3072
Closes #2726
Updates #2496 but to close needs to be applied to 4.11 accoring to ticket.
Check in init3 not needed since same data is already checked in init2
stage. Adds an extra check that the APB register space is available before
accessing it.
Updates #2331 but needs to be applied to 4.11 according to ticket.
Fixes #2878
Update #2133.
The SPARC ABI is a bit special with respect to the floating point context.
The complete floating point context is volatile. Thus, from an ABI point
of view nothing needs to be saved and restored during a context switch.
Instead the floating point context must be saved and restored during
interrupt processing. Historically, the deferred floating point switch was
used for SPARC and the complete floating point context is saved and
restored during a context switch to the new floating point unit owner.
This is a bit dangerous since post-switch actions (e.g. signal handlers)
and context switch extensions may silently corrupt the floating point
context.
The floating point unit is disabled for interrupt handlers. Thus, in case
an interrupt handler uses the floating point unit then this will result in a
trap (INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT).
In uniprocessor configurations, a lazy floating point context switch is
used. In case an active floating point thread is interrupted (PSR[EF] == 1)
and a thread dispatch is carried out, then this thread is registered as the
floating point owner. When a floating point owner is present during a
context switch, the floating point unit is disabled for the heir thread
(PSR[EF] == 0). The floating point disabled trap checks that the use of the
floating point unit is allowed and saves/restores the floating point context
on demand.
Update #3077.
Rename SPARC_USE_SAFE_FP_SUPPORT in SPARC_USE_SYNCHRONOUS_FP_SWITCH.
Update comment.
Update #3077.
This patch adds NOP instructions to prevent instruction sequences
that are sensitive to the LEON3FT B2BST errata. See GRLIB-TN-0009:
"LEON3FT Stale Cache Entry After Store with Data Tag Parity Error"
for more information.
The sequences are only modified if __FIX_LEON3FT_B2BST is defined.
The patch works in conjunction with the -mfix-ut700, -mfix-gr712rc,
and -mfix-ut699 GCC flags that prevents the sensitive sequences from
being generated.
Update #3057.
Close #3071.
Update #3059.
Update #3059.
Implement the Processor_mask via <sys/bitset.h>. Provide
_Processor_mask_To_uint32_t() to enable its use in device specific
routines, e.g. interrupt affinity register in an interrupt controller.
Update #3059.
Change bsp_interrupt_vector_enable() and bsp_interrupt_vector_disable()
to not return a status code. Add bsp_interrupt_assert() and use it to
validate the vector number in the vector enable/disable implementations.
There is no need to save the thread pointer in _CPU_Context_switch()
since it is a thread invariant. It is initialized once in
_CPU_Context_Initialize().
The SYM define concatenates the input with the compiler set
__USER_LABEL_PREFIX__ define. This define appears to be '_' in GCC but
empty in Clang. Therefore when compiling with Clang/LLVM 'SYM(start)'
and 'start' defines the same symbol, and the compiler complains that the
symbol is defined twice.
- All references of %0 changed to %g0
- 'call label,0' changed to 'call label'. According to the sparc
specification call does not take any registers
- '.seg "text"' changed to '.section ".text"'
- the synonym stub is replaced with stb
- the synonym stuh is replaced with sth
The following functions now reports to the user that an overrun has
occured by returning errno EIO:
* grtc_read, on overrun and no more data in the DMA buffer
* ioctl(GRTC_IOC_RECV), on overrun and no more frames in the DMA buffer
* ioctl(GRTC_IOC_ISSTARTED), EIO is returned on overrun
Since DMA buffers are managed by the user, responsibility is put on
the user to cope with SMP in the application.
This driver was initially intended for APBUART access on GRLIB PCI
peripherals (AMBA-over-PCI). There are already many APBUART drivers
for LEON. Instead of using this one the termios APBUART should work
on AMBA-over-PCI systems with recent changes on LEON3, however that
has not been tested yet.
The common interrupt layer for GRLIB PCI perihperals is prepared for SMP
support by this patch. The existing locking (interrupt disabling) is
replaced by a new requirement on the user to implement locking before
calling the genirq API. This approach avoids taking more locks than
necessary.
The split up of the locks also introduces that the user must allocate
memory to describe ISR handlers, to avoid calling malloc()/free() while
possessing a spin-lock and interrupts are globally disabled.
It is also required to use semaphore release instead of flush when stopping
or on BUSOFF/AHBERR condition. Otherwise a task just about to wait
(taking the semaphore) could end up locked because the semaphore count is
still the same.
There was previously a scenario where the semaphore flush would not always make
semaphore obtain to return in case of BUSOFF, AHBERROR or grcan_stop. It has to
do with the rtems_semaphore_flush() not releasing the semaphore but just aborts
any _current_ waiter.
this is to avoid owning the spin-lock during semaphore operations.
