Update #3285.
Update #2133.
This makes the new Termios devices independent of device major/minor
numbers. It enables BSP independent Termios device drivers which may
reside in the cpukit domain. These drivers require an IMFS and do not
work with the device file system. However, the device file system
should go away in the future.
Only the context of the console device was used and this is wrong in
case more than one APBUART device is available.
Move interrupt lock to device context and expose only this structure to
the read, write and set attributes device handler. This makes these
device handler independent of the general Termios infrastructure
suitable for direct use in printk() support.
Move the APBUART console driver support to the shared SPARC area so that
it can be reused by other BSPs. Only the console driver initialization
is now BSP specific.
On SMP rtems_interrupt_lock_context must be used. Most tests fail with a
NULL pointer exception when exiting, except on NGMP where main memory is
at 0x00000000.
This reverts commit 7579e255127ee0cf04901bbab6c1538559053508.
Improve QEMU to support AMBA plug and play instead.
Move declaration of global variables and functions to <leon.h> header
file. Make several global variables and functions static.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Some register layout definitions for LEON3 reside in ambapp.h which
does not really has anything to do with device registers. The
register structures has been incorrectly named LEON3_*, the cores
are not only used on LEON3 but on LEON4 and perhaps on LEON5 when
that day comes. Some structures has been renamed according to the
GRLIB core name instead, which CPU that actually use it is not
relevant. Drivers has been updated with the new names.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
The comment in configure.ac is probably inherited from the LEON2
BSP. The LEON3 console driver implements a "flush" mechanism on
console_close() in order to solve the problem described with
sis/LEON2.
The UART indexing was rather a mess when MP was enabled. The changes
introduces two weak variables syscon_uart_index and debug_uart_index
so that the user can override the default system debug console (printk)
and system console UART (/dev/console).
The two weak variables is updated on boot to reflect the "real" UART
index.
MINOR DEVICE-FS-NAME UART
0 /dev/console Default /dev/console_a, user selectable
1 /dev/console_a APBUART[0] (missing by default)
2 /dev/console_b APBUART[1]
/dev/console_a is by default renamed /dev/console and assigned minor=0,
but user can select /dev/console_['a'+N] to be renamed to /dev/console
by setting syscon_uart_index=N.
On a MP system the console renamed to /dev/console is selected by CPU
index (LEON3_Cpu_Index). /dev/console_['a' + LEON3_Cpu_Index] is
renamed unless overrided. Resource sharing is performed by the user,
one should not open/access a console that another OS instance uses.
This patch also moves the initialization of the UART to the open()
call, note that before APBUART[0] was always enabled as debug uart
even on MP systems. The debug UART is initialized at boot time.
* Makefile.am, amba/amba.c, console/console.c, console/debugputs.c,
startup/bspstart.c: Rework initialization order so AMBA bus is
scanned earlier. This lets us look for UARTs earlier and support
printk as early as bsp_start() returning.
* console/console.c:
Reflect changes to rtems_termios_callbacks->write.
* Makefile.am, startup/bspstart.c:
Use ../../sparc/shared/bsppretaskinghook.c.
* console/console.c: Remove sis comment.
* console/console.c: Fix warning.
* Makefile.am, console/console.c, console/debugputs.c, include/bsp.h,
startup/setvec.c: Split idle method into its own file. Properly note
to confdefs.h that this BSP has its own idle thread. Also address use
of maximum termios constant in debug IO.
* startup/bspidle.S: New file.
* console/console.c, timer/timer.c: Fix typos in previous commit
uncovered by MP build.
* amba/amba.c, clock/ckinit.c, console/console.c, include/bsp.h,
startup/bspstart.c, timer/timer.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* console/console.c, leon_greth/leon_greth.c,
leon_smc91111/leon_smc91111.c: Remove warnings.
* Makefile.am, preinstall.am: New files, split of printk.
* console/console.c, console/debugputs.c: Split printk support out.
* include/spacewire.h: Removed.
* Makefile.am, preinstall.am: Use the following new drivers from
sparc/shared: PCI, b1553BRM, SpaceWire(GRSPW), CAN (GRCAN), Raw UART.
* clock/ckinit.c, console/console.c, leon_greth/leon_greth.c,
leon_smc91111/leon_smc91111.c: LEON3 BSP drivers updated to use new
AMBA PnP scanning functions. Affected drivers:
amba/amba.c,clock/ckinit.c,console/console.c,
leon_greth/leon_greth.c, leon_smc9111.c.
