PR 2015/bsps
Since the configuration struct is always present one can let
DATA initialize it to reduce footprint, at the same time it
is made weak to let the user able to configure the SHM driver
without editing the driver code.
Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
* smp/getcpuid.c: Fix header from accidental and irrelevant copy and
paste.
Jennifer Averett <jennifer.averett@OARcorp.com>
PR 1801/bsps
* Makefile.am, include/leon.h: Add SMP support to LEON3 BSP.
* smp/getcpuid.c, smp/smp_leon3.c: New files.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* tools/.cvsignore, tools/ChangeLog, tools/Makefile.am,
tools/configure.ac, tools/runtest.in: Removed.
PR 1783/bsps
* include/bsp.h: Remove dead prototypes of Clock_delay() and delay().
Neither had bodies.
PR 1729/cpukit
* Makefile.am, configure.ac: Add next step in SMP support. This adds an
allocated array of the Per_CPU structures to support multiple cpus vs
a single instance of the structure which is still used if SMP support
is disabled. Configuration support is also added to explicitly enable
or disable SMP. But SMP can only be enabled for the CPUs which will
support it initially -- SPARC and i386. With the stub BSP support, a
BSP can be run as a single core SMP system from an RTEMS data
structure standpoint.
PR 1748/bsps
* clock/ckinit.c, include/leon.h: When the clock tick generates an
interrupt WHILE we have interrupts disabled doing a get TOD or
uptime, the get nanoseconds handler was returning a bogusly large
number.
* amba/amba.c, include/tm27.h, shmsupp/lock.c, startup/bspstart.c,
startup/spurious.c:
* timer/timer.c: Include <rtems/btimer.h>.
* Makefile.am: Add bspinit.c from the shared BSP files.
* configure.ac: Remove AC_CHECK_SIZEOF([void *]).
* configure.ac: Added AC_CHECK_SIZEOF macro.
* Makefile.am, amba/amba.c, console/console.c, console/debugputs.c,
startup/bspstart.c: Rework initialization order so AMBA bus is
scanned earlier. This lets us look for UARTs earlier and support
printk as early as bsp_start() returning.
* startup/linkcmds: Include basic linker command file and define only
board specific values. Define RAM and PROM limits only if not defined
by command line arguments.
* Makefile.am, preinstall.am: Reflect changes above.
PR 1483/cpukit
* pci/pci.c: Rename pci_config into rtems_pci_config_t.
* console/console.c:
Reflect changes to rtems_termios_callbacks->write.
* Makefile.am, startup/bspstart.c:
Use ../../sparc/shared/bsppretaskinghook.c.
* console/console.c: Remove sis comment.
* amba/amba.c: Re-add tmp.
* make/custom/leon3.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/leon3.cfg: New (relocated from /make/custom).
PR 1445/BSPs
* pci/pci.c: Rename pci_[read|write]_config* functions into
BSP_pci_[read|write]_config* and make them static.
* pci/pci.c: Add prototypes for BusCountPCI(void), init_pci(void).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Fix typo.
* console/console.c: Fix warning.
* startup/ithread.S: Removed. Now bspidle.S.
* Makefile.am, console/console.c, console/debugputs.c, include/bsp.h,
startup/setvec.c: Split idle method into its own file. Properly note
to confdefs.h that this BSP has its own idle thread. Also address use
of maximum termios constant in debug IO.
* startup/bspidle.S: New file.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* startup/linkcmds: Start of RTEMS Work Area must be on 16 byte
boundary on the SPARC.
PR 1391/bsps
* startup/spurious.c: Format was %d but had leading 0x.
PR 1390/bsps
* startup/linkcmds: Fix sections so C++ global constructors and
destructors work with late model (>= 4.3) gcc versions.
* bsp_specs: Remove -e start from %link.
* include/coverhd.h: Removed.
* clock/ckinit.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am: bsp_cleanup() had the same code which was executed when
you returned from boot_card() to start.S. So just use the stub
bsp_cleanup() implementation and remove a file.
* Makefile.am, startup/bspstart.c: Use shared bsp_get_work_area() into
its own file and use BSP Framework to perform more initialization.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* timer/timer.c: Convert to "bool".
* timer/timer.c: Convert using "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
