path: root/c/src/lib/libbsp/shmdr/initlq.c (follow)
* 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-181-34/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * shmdr/addlq.c, shmdr/cnvpkt.c, shmdr/dump.c, shmdr/fatal.c, shmdr/getlq.c, shmdr/getpkt.c, shmdr/init.c, shmdr/initlq.c, shmdr/intr.c, shmdr/mpci.h, shmdr/mpisr.c, shmdr/poll.c, shmdr/README, shmdr/receive.c, shmdr/retpkt.c, shmdr/send.c, shmdr/setckvec.c, shmdr/shm_driver.h: Remove (Moved to c/src/libchip/shmdr). 2003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bspstart.am: Use .$(OBJEXT) instead of .o. * Makefile.am: Remove shmdr. 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Use $(mkdir_p) instead of $(mkinstalldirs). 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * bsp.am: Replace bsplibdir by project_libdir. Use mkdir_p instead of mkinstalldirs. Remove dirs from PRE/TMPINSTALL_FILES. 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Remove project_libdir. 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Misc. fixes. * bsp.am: Add project_libdir. 2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bspstart.am: New. 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Merge-in shared/Makefile.am, shmdr/Makefile.am. * shared/Makefile.am: Remove. * shmdir/Makefile.am: Remove. * bsp.am: Add preinstallation dirstamp support. 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: Remove all-local: $(ARCH). 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Reworked. 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Reflect having moved automake/. * shmdr/Makefile.am: Reflect having moved automake/. 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: Reflect having merged configure.ac into ../../configure.ac. 2003-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove (Merged into ../../configure.ac). * Makefile.am: Reflect having merged configure.ac into ../../configure.ac. 2003-03-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove AC_CONFIG_AUX_DIR. 2003-02-14 Joel Sherrill <joel@OARcorp.com> AMD a29k port declared obsolete. * a29k/.cvsignore, a29k/ChangeLog, a29k/Makefile.am, a29k/acinclude.m4, a29k/configure.ac, a29k/portsw/.cvsignore, a29k/portsw/ChangeLog, a29k/portsw/Makefile.am, a29k/portsw/README, a29k/portsw/bsp_specs, a29k/portsw/configure.ac, a29k/portsw/times, a29k/portsw/console/.cvsignore, a29k/portsw/console/Makefile.am, a29k/portsw/console/concntl.h, a29k/portsw/console/console.c, a29k/portsw/console/serial.c, a29k/portsw/console/serial.h, a29k/portsw/include/.cvsignore, a29k/portsw/include/Makefile.am, a29k/portsw/include/bsp.h, a29k/portsw/start/.cvsignore, a29k/portsw/start/Makefile.am, a29k/portsw/start/amd.ah, a29k/portsw/start/pswmacro.ah, a29k/portsw/start/register.S, a29k/portsw/start/register.ah, a29k/portsw/start/start.S, a29k/portsw/startup/.cvsignore, a29k/portsw/startup/Makefile.am, a29k/portsw/startup/bspclean.c, a29k/portsw/startup/bspstart.c, a29k/portsw/startup/linkcmds, a29k/portsw/startup/main.c, a29k/portsw/startup/ramlink, a29k/portsw/startup/romlink, a29k/portsw/startup/setvec.c, a29k/portsw/wrapup/.cvsignore, a29k/portsw/wrapup/Makefile.am: Removed. 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_PREREQ(2.57). 2003-02-03 Joel Sherrill <joel@OARcorp.com> * shmdr/Makefile.am: Add .h files to PREINSTALL_FILES not TMPINSTALL_FILES. 2003-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: install mpci.h and shm_driver.h. Eliminate OBJS. 2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: Don't include @RTEMS_BSP@.cfg. 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove RTEMS_CHECK_BSP_CACHE. 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: Use .$(OBJEXT) instead of .o. 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * include/Makefile.am: Remove. * include/.cvsignore: Remove. * include/rtems/Makefile.am: Remove. * include/rtems/.cvsignore: Remove. * include/rtems/score/Makefile.am: Remove. * include/rtems/score/.cvsignore: Remove. 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove RTEMS_BSP_ALIAS. Add RTEMS_CHECK_BSP_CACHE. Replace $bspdir with $RTEMS_BSP_FAMILY. 2002-08-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: Remove include/Makefile, include/rtems/Makefile, include/rtems/score/Makefile (Eliminate targopts.h). * Makefile.am: Remove include from SUBDIRS (Eliminate targopts.h) 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Add bsplib_DATA = bsp_specs. 2002-06-25 Joel Sherrill <joel@OARcorp.com> * Thomas Doerfler <Thomas.Doerfler@imd-systems.de> added m68k support to the shared gdb stub glue thus adding a directory at the top shared level. * shared/gdbstub: New directory. * configure.ac: Modified to reflect above. 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rtems/score/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * shmdr/Makefile.am: Remove AUTOMAKE_OPTIONS. 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Add line break, remove comment. 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. 2001-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Use @subdirs@ instead of RTEMS_LIBBSP_CPU_SUBDIR. * configure.in: AC_PREREQ(2.52), apply RTEMS_CPU_SUBDIRS, remove RTEMS_LIBBSP_CPU_SUBDIR. 2001-09-28 Joel Sherrill <joel@OARcorp.com> * shared/bootcard.c, shared/main.c: Now call int c_rtems_main() not main(). 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * shmdr/Makefile.am: Use 'PREINSTALL_FILES ='. 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Use SUBDIRS = instead of SUBDIRS += to make automake-1.5 happy. * include/rtems/score/Makefile.am: Use CLEANFILES = to make automake-1.5 happy. * bsp.am: Use PREINSTALL_FILES = to make automake-1.5 happy. 2001-02-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * bsp.am: Fix automake version number in comment. 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. 2000-09-25 Joel Sherrill <joel@OARcorp.com> * shmdr/shm_driver.h: Added _AM29K entry. May not be correct. 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> * shmdr/Makefile.am: Include compile.am 2000-08-10 Joel Sherrill <joel@OARcorp.com> * ChangeLog: New file.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | * addlq.c, cnvpkt.c, dump.c, fatal.c, getlq.c, getpkt.c, init.c, initlq.c, intr.c, mpci.h, mpisr.c, poll.c, receive.c, retpkt.c, send.c, setckvec.c, shm_driver.h: URL for license changed.
* Renamed shm.h to shm_driver.h to avoid conflicts with POSIX shm.h.Joel Sherrill1999-11-301-1/+1
| | | | | Renamed file shmsupp/intr.c in some BSPs to shmsupp/cause_intr.c to avoid conflict with rtems/src/intr.c (Classic API Interrupt Manager).
* Initial revisionJoel Sherrill1995-05-111-0/+35
