The VME support is only used by powerpc BSPs.
Update #3285.
Update #3254.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
* shared/vmeUniverse/vmeUniverse.c: print message and
let vmeUniverseIntLoopbackTst() fail if odd-numbered
vector is used (cannot program the chip to reply with
such a vector).
* vmeUniverse/vmeUniverse.c, vmeUniverse/vmeTsi148.c:
include <rtems/pci.h> instead of <bsp/pci.h>.
* vmeUniverse/vmeUniverse.c: fixed compiler warning;
moved struct attributes as directed by gcc warning.
silenced compiler warnings caused by type changes
in byteorder.h (volatile unsigned * -> volatile uint32_t *)
compiler warnings.
* vmeUniverse/vmeUniverse.c: Use uint32_t for pci_ulong.
* vmeUniverse/vmeUniverse.c: Use size_t for sizes.
* vmeUniverse/README.porting, vmeUniverse/README.universe:
updated, added more information for BSP implementors.
* vmeUniverse/VMEDMA.h (added): VME DMA API definition.
* vmeUniverse/bspVmeDmaList.h (added), vmeUniverse/bspVmeDmaListP.h (added),
* vmeUniverse/bspVmeDmaList.c (added):
Driver-independent code for linked-list DMA (public + private headers,
implementation).
* vmeUniverse/vmeUniverseDMA.h (added), vmeUniverse/vmeTsi148DMA.h (added):
interface to new DMA features of drivers.
* vmeUniverse/vme_amd_defs.h: Added definition for data-width
hint bits (VME_MODE_DBWxx).
* vmeUniverse/vmeTsi148.c: added DMA support. Added support for
data-width hint/modifier bits.
* vmeUniverse/vmeUniverse.c, vmeUniverse/vmeUniverse.h:
Added support for data-width hint/modifier bits.
Added support for xxx_BLT, xxx_MBLT address modifiers.
Restrict DBW to 32 in non-MBLT modes (except single-beat;
a comment is in README.universe). Updated DMA support to
implement new VMEDMA.h API. Added support for non-incrementing
VME addresses. Restrict data width to 32 for single-beat AMs
when the universe would use MBLT for DMA.
* vmeUniverse/vmeTsi148.c, vmeUniverse/vmeTsi148.h,
* vmeUniverse/vmeUniverse.c, vmeUniverse/vmeUniverse.h,
* vmeUniverse/vme_am_defs.h:
Added SLAC/Stanford Authorship Note / Copyright + Liability Disclaimer.
flags for 2eSST and DBW16.
* vmeUniverse/vmeUniverse.h: Removed AM definitions and include vme_am_defs.h
instead. Declare new routine vmeUniverseMapCRG(). Export 'irq manager' API
only if __INSIDE_RTEMS_BSP__ defined. Renamed 'shared' argument to
vmeUniverseInstallIrqMgrAlt() to 'flags' since now more options are available.
Added new flag to install 'posted-write' workaround.
* vmeUniverse/vmeUniverse.c: Allow BSP to override BSP_PCI2LOCAL_ADDR()
macro. Data width of outbound port can now be restricted to 16-bit
(if new DBW16 flag set in address modifier). Added vmeUniverseMapCRG()
for mapping local registers onto VME. Interrupt manager now implements
a workaround (enabled at installation time) which flushes the write-fifo
after user ISR returns. This requires the universe's registers to be
accessible from VME (either CSR space or CRG mapped to A16/A24/A32),
though.
* vmeUniverse/vmeTsi148.h: vmeTsi148ClearVMEBusErrors() now returns
the fault address as a 32-bit address (not ulonglong anymore). The
driver only supports 32-bit addresses. Declare new routine vmeTsi148MapCRG().
Export 'irq manager' API only if __INSIDE_RTEMS_BSP__ defined.
Renamed 'shared' argument to vmeTsi148InstallIrqMgrAlt() to 'flags'
to allow more options to be supported. Added comments explaining the
'posted-write' workaround implemented by the interrupt manager.
* vmeUniverse/vmeTsi148.c: Clear 'SYSFAIL' during initialization.
Allow BSP to override BSP_PCI2LOCAL_ADDR() macro. Added support for
2eSST when configuring windows (untested - I have no 2eSST).
Added vmeTsi148MapCRG() for mapping local registers onto VME.
Implemented 'posted-write' workaround for interrupt manager
(consult source for details).
* vmeUniverse/vmeTsi148.c, vmeUniverse/vmeUniverse.c,
vmeUniverse/vmeUniverse.h, vmeUniverse/vme_amd_defs.h:
Added 2F address modifier for VME64 CSR access.
vmeUniverse/vme_amd_defs.h: No longer enable posted-writes
on master windows (creates race-condition on memory-mapped
devices). A new flag allows for signalling that a window
maps 'ordinary memory'. Disable VME IRQ level if no
handler is registered with interrupting vector.
* vmeUniverse/vmeUniverse.c: Eliminate obsolete types.
Remove CVS log.
* shared/vmeUniverse/vmeTsi148.c, shared/vmeUniverse/vmeTsi148.h,
shared/vmeUniverse/vme_am_defs.h: New files.
* Makefile.am, shared/vmeUniverse/README.universe,
shared/vmeUniverse/vmeUniverse.c, shared/vmeUniverse/vmeUniverse.h:
Several VME related upgrades and fixes, hopefully addressing PR#835:
vmeUniverse driver now supports shared interrupts. vmeUniverse now
supports up to four wires between universe and PIC. A new irq mgr
installation routine has been added allowing to use the new features.
(old version is still present for bwd compatibility). Calls have been
added to change interrupt routing (e.g., if wires have different
priorities at the PIC this feature can be used to configure
priorites). Routine for testing VME interrupts has been added (useful
during BSP development). A new header defining standard VME address
modes has been added so that the VME API doesn't have to #include a
particular bridge driver header. For all driver entry points, a 'XX'
variant has been added which allows to pass the chip's base address
[in case a second universe is sitting on a VME card :-)]. Driver now
uses interrupt line as read from PCI config. space (without offset)
BSP needs to use PCI fixup if necessary. Added a driver for the
tundra tsi148 VME bridge.
PR 779/bsp
* vmeUniverse/vmeUniverse.c: add parameter to new exception interrupt
handlers in powerpc bsps
* vmeUniverse/README.porting, vmeUniverse/vmeUniverse.c: Continue PCI
API unification. All use pci_find_device().
* vmeUniverse/README.porting, vmeUniverse/vmeUniverse.c: Make PCI
initialize function part of the unified PCI API as pci_initialize().
* vmeUniverse/vmeUniverse.c: Use PCI_MEM_BASE_ADJUSTMENT because some
boards -- notably the MVME2100 -- return the physical address, not an
offset in PCI memory space.
PR 380/bsps
make printk format strings compliant with libcpu/printk.
minor fixes and lazy init bugfix.
PR 349/bsps
* shared/README.universe, shared/vmeUniverse/README.porting
shared/vmeUniverse/README.universe, shared/vmeUniverse/vmeUniverse.c,
shared/vmeUniverse/vmeUniverse.h: Update of the VME universe driver.
* vmeUniverse/README.universe, vmeUniverse/vmeUniverse.c,
vmeUniverse/vmeUniverse.h: New files.
* Makefile.am: Modified to reflect addition of files.
* Per PR214, contributes a driver for the TUNDRA UNIVERSE
VME-PCI bridge to libbsp/shared.
NOTE: This driver is maintained _outside_ RTEMS by Till. Please
forward future modifications to him.
