* simsh4/.cvsignore, simsh4/ChangeLog, simsh4/Makefile.am,
simsh4/README, simsh4/bsp_specs, simsh4/configure.ac,
simsh4/preinstall.am, simsh4/clock/ckinit.c,
simsh4/console/console.c, simsh4/include/.cvsignore,
simsh4/include/bsp.h, simsh4/include/coverhd.h,
simsh4/include/ramdisk.h, simsh4/include/syscall.h,
simsh4/include/tm27.h, simsh4/start/start.S,
simsh4/startup/hw_init.c, simsh4/startup/linkcmds,
simsh4/startup/linkcmds-le, simsh4/startup/linkcmds-le.coff,
simsh4/timer/timer.c, simsh4/tools/.cvsignore,
simsh4/tools/ChangeLog, simsh4/tools/Makefile.am,
simsh4/tools/configure.ac, simsh4/tools/runtest.in: Removed.
* console/console.c: Remove all references to console_reserve_resources
and termios_reserve_resources.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
include/ramdisk.h, start/start.S, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le.coff,
timer/timer.c, tools/runtest.in: URL for license changed.
tools/Makefile.am: Reflect having moved automake.
* console/console.c, startup/linkcmds: Removed warnings.
* clock/ckinit.c, console/console.c: Removed warnings.
* tools/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Added support for START_HW_INIT.
* console/Makefile.am: Removed VPATH.
* include/Makefile.am: Added missing ramdisk.h to include_HEADERS.
* startup/linkcmds: Do not force output format to coff-sh.
* startup/linkcmds-le: Comment out force of output format and add
comment questioning need to have special linkcmds for little endian.
* wrapup/Makefile.am: Add ramdisk to list of BSP_PIECES.
* clock/Makefile.am, clock/ckinit.c, clock/.cvsignore, Makefile.am,
README, bsp_specs, console/Makefile.am, console/console.c,
console/.cvsignore, include/Makefile.am, include/bsp.h,
include/coverhd.h, include/syscall.h, include/ramdisk.h,
include/.cvsignore, start/Makefile.am, start/start.S,
start/.cvsignore, startup/Makefile.am, startup/bspstart.c,
startup/hw_init.c, startup/linkcmds, startup/linkcmds-le,
startup/linkcmds-le.coff, startup/.cvsignore, timer/Makefile.am,
timer/timer.c, timer/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore,
configure.ac, .cvsignore, ChangeLog: New files.
Reviewed and updated to latest automake and autoconf standards
by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
