* | bsps: Move start files to bsps | Sebastian Huber | 2018-04-20 | 1 | -278/+0 |
| | | | | | | This patch is a part of the BSP source reorganization. Update #3285. | ||||
* | gensh4: Improve ROM vs RAM startup configuration | Joel Sherrill | 2014-08-25 | 1 | -3/+9 |
* | 2010-04-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-24 | 1 | -4/+0 |
| | | | | * start/start.S: Verify boot_card is invoked properly with argc, argv. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -1/+1 |
* | 2009-04-28 Chris Johns <chrisj@rtems.org> | Chris Johns | 2009-04-28 | 1 | -1/+5 |
| | | | | * start/start.S: Update for boot_card command line change. | ||||
* | Remove duplicate white lines. | Ralf Corsepius | 2004-04-21 | 1 | -2/+0 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-16 | 1 | -5/+5 |
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
* | * start/start.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 2004-04-02 | 1 | -1/+1 |
| | | | | | | | * console/console.c, hw_init/hw_init.c, include/bsp.h, include/coverhd.h, include/sdram.h, start/start.S, startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram: URL for license changed. | ||||
* | 2001-10-11 Alexandra Kossovsky <sasha@oktet.ru> | Joel Sherrill | 2001-10-11 | 1 | -0/+277 |
* Makefile.am, README, bsp_specs, .cvsignore, include/Makefile.am, include/bsp.h, include/coverhd.h, include/sdram.h, include/.cvsignore, start/Makefile.am, start/start.S, start/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/linkcmds, startup/linkcmds.rom, startup/linkcmds.rom2ram, startup/.cvsignore, wrapup/Makefile.am, wrapup/.cvsignore, hw_init/Makefile.am, hw_init/hw_init.c, hw_init/.cvsignore, times, configure.ac: New files. Reviewed and updated to latest automake and autoconf standards by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. |
