path: root/c/src/lib/libbsp/sh/configure.ac (follow)
* build: Remove old build systemSebastian Huber2021-09-211-20/+0
| | | | | Close #3250. Close #4081.
* bsps: Remove AC_CONFIG_SRCDIR()Sebastian Huber2018-04-231-1/+0
| | | | | | | | | | | This AC_CONFIG_SRCDIR() is just a sanity check in this insane build system. Since all content of c/src/lib/libbsp/@RTEMS_CPU@/@RTEMS_BSP_FAMILY@ is bound to be moved it makes no sense to keep it. This patch is a part of the BSP source reorganization. Update #3285.
* configure: Add subdir-objects to all automake flags.Chris Johns2018-04-111-1/+1
| | | | | | | | | | | This option silences warning with automake-1.16.1 allowing us to upgrade to that version. This change has been tested with automake-1.12.6 and automake-1.16.1. It seems version 1.16.1 configures slower than 1.12.6 for the same source and BSP. The newer versions is 6 second slower. Close #3387.
* Remove make preinstallChris Johns2018-01-251-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* Update bug report URLSebastian Huber2014-12-051-1/+1
* Require automake-1.12.2.Ralf Corsépius2012-07-191-1/+1
* Require autoconf-2.69.Ralf Corsépius2012-07-191-1/+1
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+2
* Remove CVS-Ids.Ralf Corsépius2012-05-041-2/+0
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-021-2/+2
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* Whitespace removal.Ralf Corsepius2009-11-281-1/+1
* 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-12-021-1/+1
| | | | * configure.ac: New BUG-REPORT address.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-171-2/+2
| | | | * configure.ac: Require autoconf-2.60. Require automake-1.10.
* Remove shared/Makefile.am.Ralf Corsepius2005-10-161-2/+1
* Fix typo in previous change.Ralf Corsepius2004-09-241-1/+1
* 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-09-241-1/+1
| | | | * configure.ac: Require automake > 1.9.
* 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-121-1/+1
| | | | * configure.ac: RTEMS_CHECK_BSPDIR([$RTEMS_BSP_FAMILY]).
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+2
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-10-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-201-1/+0
| | | | | * acinclude.m4: Reflect changes to bootstrap. * configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-1/+1
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-111-1/+0
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-1/+1
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-061-1/+0
| | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-2/+2
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+25
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
