path: root/c/src/lib/libbsp/powerpc/virtex5/configure.ac (follow)
* build: Remove old build systemSebastian Huber2021-09-211-45/+0
| | | | | Close #3250. Close #4081.
* virtex5: Move -Dxxx to configure.acJoel Sherrill2018-05-181-0/+2
| | | | Updates #3425.
* bsps: Remove AC_CONFIG_SRCDIR()Sebastian Huber2018-04-231-1/+0
| | | | | | | | | | | This AC_CONFIG_SRCDIR() is just a sanity check in this insane build system. Since all content of c/src/lib/libbsp/@RTEMS_CPU@/@RTEMS_BSP_FAMILY@ is bound to be moved it makes no sense to keep it. This patch is a part of the BSP source reorganization. Update #3285.
* build: Remove subdir-objects from BSP configure.acSebastian Huber2018-04-121-1/+1
| | | | | | | The subdir-objects do not work currently due to BSP sources in bsps and c and the existing build tree layout. Update #3387.
* configure: Add subdir-objects to all automake flags.Chris Johns2018-04-111-1/+1
| | | | | | | | | | | This option silences warning with automake-1.16.1 allowing us to upgrade to that version. This change has been tested with automake-1.12.6 and automake-1.16.1. It seems version 1.16.1 configures slower than 1.12.6 for the same source and BSP. The newer versions is 6 second slower. Close #3387.
* bsps: Move config macros to RTEMS_BSP_CONFIGURESebastian Huber2018-04-041-5/+0
| | | | | | | | Provide HAS_NETWORKING and HAS_SMP Automake conditionals for all BSPs. This patch is a part of the BSP source reorganization. Update #3285.
* Remove make preinstallChris Johns2018-01-251-0/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | A speciality of the RTEMS build system was the make preinstall step. It copied header files from arbitrary locations into the build tree. The header files were included via the -Bsome/build/tree/path GCC command line option. This has at least seven problems: * The make preinstall step itself needs time and disk space. * Errors in header files show up in the build tree copy. This makes it hard for editors to open the right file to fix the error. * There is no clear relationship between source and build tree header files. This makes an audit of the build process difficult. * The visibility of all header files in the build tree makes it difficult to enforce API barriers. For example it is discouraged to use BSP-specifics in the cpukit. * An introduction of a new build system is difficult. * Include paths specified by the -B option are system headers. This may suppress warnings. * The parallel build had sporadic failures on some hosts. This patch removes the make preinstall step. All installed header files are moved to dedicated include directories in the source tree. Let @RTEMS_CPU@ be the target architecture, e.g. arm, powerpc, sparc, etc. Let @RTEMS_BSP_FAMILIY@ be a BSP family base directory, e.g. erc32, imx, qoriq, etc. The new cpukit include directories are: * cpukit/include * cpukit/score/cpu/@RTEMS_CPU@/include * cpukit/libnetworking The new BSP include directories are: * bsps/include * bsps/@RTEMS_CPU@/include * bsps/@RTEMS_CPU@/@RTEMS_BSP_FAMILIY@/include There are build tree include directories for generated files. The include directory order favours the most general header file, e.g. it is not possible to override general header files via the include path order. The "bootstrap -p" option was removed. The new "bootstrap -H" option should be used to regenerate the "headers.am" files. Update #3254.
* libbsp/*/*/configure.ac: Remove references to bsp_specs in AC_CONFIG_SRCDIRJoel Sherrill2017-11-271-1/+1
| | | | Updates #3250.
* bsps: Simplify RTEMS_BSP_CLEANUP_OPTIONSSebastian Huber2017-11-221-1/+1
| | | | | | | | | Remove BSP-specific defaults for RTEMS_BSP_CLEANUP_OPTIONS to simplify the BSP configuration and documentation. Change defaults to: BSP_PRESS_KEY_FOR_RESET=0 BSP_RESET_BOARD_AT_EXIT=1 BSP_PRINT_EXCEPTION_CONTEXT=1
* Update bug report URLSebastian Huber2014-12-051-1/+1
* Require automake-1.12.2.Ralf Corsépius2012-07-191-1/+1
* Require autoconf-2.69.Ralf Corsépius2012-07-191-1/+1
* Add Virtex4 and Virtex5 BSPsRic Claus2012-03-301-0/+48
This commit covers at least PR2020, 2022, and 2023. This patch adds all of the code for both BSPs, modifications to libcpu/powerpc for the ppc440, and some updates to the BSPs from follow up review and testing. These BSPs should be good baselines for future development. The configurations used by Ric are custom and have a non-standard NIC. They also do not have a UART. Thus the current console driver just prints to a RAM buffer. The NIC and UART support are left for future work. When the UART support is added, moving the existing "to RAM" console driver to a shared location is likely desirable because boards with no debug UART port are commonly deployed. This would let printk() go to RAM.
