Update #3285.
Update #3285.
The size of the sample executables without this option were:
136928 2284 134078500 134217712 7fffff0 base_sp.exe
152124 2168 134063412 134217704 7ffffe8 hello.exe
96317 1892 134119500 134217709 7ffffed minimum.exe
658001 6274 133553428 134217703 7ffffe7 fileio.exe
161562 2380 134053772 134217714 7fffff2 nsecs.exe
229008 2668 133986040 134217716 7fffff4 paranoia.exe
140224 2292 134075204 134217720 7fffff8 ticker.exe
139564 2308 134075836 134217708 7ffffec unlimited.exe
951004 147150 133119544 134217698 7ffffe2 cxx_iostream.exe
256264 9352 133952104 134217720 7fffff8 cdtest.exe
254760 2788 133960156 134217704 7ffffe8 capture.exe
The size of the sample executables with this option enabled were:
123180 2268 134092272 134217720 7fffff8 base_sp.exe
136152 2112 134079448 134217712 7fffff0 hello.exe
53640 1560 134162508 134217708 7ffffec minimum.exe
632433 6238 133579016 134217687 7ffffd7 fileio.exe
148538 2364 134066808 134217710 7ffffee nsecs.exe
214540 2644 134000536 134217720 7fffff8 paranoia.exe
126732 2276 134088688 134217696 7ffffe0 ticker.exe
124292 2268 134091136 134217696 7ffffe0 unlimited.exe
608992 50546 133558180 134217718 7fffff6 cxx_iostream.exe
243452 8036 133966228 134217716 7fffff4 cdtest.exe
238360 2740 133976616 134217716 7fffff4 capture.exe
The 32-bit ABIs for thread-local storage (TLS) and EABI read-only
small-data area have a conflicting register (r2) usage. Use the System
V small-data instead (here r2 is system reserved).
Use linkcmds.base. Use EABI with small-data area.
* make/custom/virtex.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/virtex.cfg: New (relocated from /make/custom).
