Update #3285.
Update #3339.
Use only one timer driver variant based on the standard PowerPC time
base.
Update #3285.
The only consumer of this variable was the ppc403 clock driver used by
the
* haleakala,
* virtex, and
* virtex4
BSPs which set bsp_timer_internal_clock unconditionally to true.
Update #3285.
BSPs can use the bsp_fatal_extension() to provide BSP-specific fatal
error handling. There is no need for a _BSP_Fatal_error().
Close #3246.
Due to a new rtems_panic() implementation, it is possible to replace the
PowerPC-specific BSP_panic() with rtems_panic(). Remove BSP_panic()
implementations.
Close #3245.
close #2211
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
The clock driver used previously the bsp_clicks_per_usec value. For a
33333333Hz time base frequency this leads to a relative error of one per
cent for example due to integer truncation.
* configure.ac, startup/bspstart.c: Use standard cache BSP options.
* Makefile.am, startup/bspstart.c: Rename BSP specific idle thread to
bsp_idle_thread and split into its own file.
* startup/bspidle.c: New file.
* startup/bspstart.c: Change prototype of IDLE thread to consistently
return void * and take a uintptr_t argument.
* Makefile.am, startup/bspstart.c: Split out bsp_get_work_area() into
its own file and use BSP Framework to perform more initialization.
* startup/bspgetworkarea.c: New file.
