* configure.ac: Add RTEMS_PROG_CCAS.
* Makefile.am: Use automake compilation rules.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Reformat for preinstallation dirstamp support.
* Makefile.am: Remove all-local: $(ARCH).
* Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* Makefile.am: Fix oversights in previous patch.
* rtems.S: Remove.
* Makefile.am: Reflect having removed rtems.S. Use AM_CPPFLAGS
instead of INCLUDES (Latest automake standard).
* rtems/score/cpu.h: Removed.
This was tracked as PR91.
* rtems/score/c_isr.inl: Deleted and contents merged into cpu.c.
* cpu.c: Received contents of c_isr.inl.
* Makefile.am: Deleted reference to c_isr.inl.
* Makefile.am: Preinstall c_isr.inl (HACK).
* ChangeLog: New file.
* support/new_exception_processing/Makefile.am,
support/old_exception_processing/Makefile.am,
support/old_exception_processing/cpu_asm.S,
support/old_exception_processing/irq_stub.S: Modified to reflect
old versus new exception processing being a per BSP option.
* support/new_exception_processing/c_isr.inl,
support/new_exception_processing/cpu.h,
support/old_exception_processing/c_isr.inl,
support/old_exception_processing/cpu.h,
support/old_exception_processing/ppc_offs.h: Removed.
* new_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* old_exception_processing/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/mmu/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/clock/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc6xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* mpc8xx/exceptions/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/include/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'PREINSTALL_FILES ='.
* shared/src/Makefile.am: Use 'CLEANFILES ='.
* mpc505/ictrl/Makefile.am, mpc6xx/clock/Makefile.am,
mpc6xx/exceptions/Makefile.am, mpc6xx/mmu/Makefile.am,
mpc8xx/include/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am, pc403/ictrl/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am:
Apply *_HEADERS instead of *H_FILES.
* shared/src/.cvsignore: Add cache.h.
* Added full support for MPC505.
* mpc505/ictrl: New directory.
* configure.in, mpc505/Makefile.am: Modified to reflect ictrl addition.
* mpc505/ictrl/.cvsignore, mpc505/ictrl/Makefile.am,
mpc505/ictrl/ictrl.c, mpc505/ictrl/ictrl.h: New files.
* mpc505/timer/timer.c: Use <rtems.h>, not "rtems.h".
* mpc505/vectors/Makefile.am: alignment exception handler now included.
* mpc505/vectors/vectors.S: Now use constants for exception numbers.
* old_exception_processing/ppc_offs.h: New file.
* old_exception_processing/Makefile.am: Account for ppc_offs.h.
* old_exception_processing/cpu.h: Make Nest and Disable levels volatile.
* old_exception_processing/cpu_asm.S: Offsets moved to ppc_offs.h.
* mpc505/timer/Makefile.am, mpc505/vectors/Makefile.am,
mpc6xx/clock/Makefile.am, mpc6xx/exceptions/Makefile.am,
mpc6xx/mmu/Makefile.am, mpc6xx/timer/Makefile.am,
mpc6xx/wrapup/Makefile.am, ppc403/clock/Makefile.am,
ppc403/console/Makefile.am, ppc403/ictrl/Makefile.am,
ppc403/timer/Makefile.am, ppc403/vectors/Makefile.am,
shared/include/Makefile.am, shared/src/Makefile.am,
wrapup/Makefile.am, mpc8xx/clock/Makefile.am,
mpc8xx/console-generic/Makefile.am, mpc8xx/cpm/Makefile.am,
mpc8xx/mmu/Makefile.am, mpc8xx/timer/Makefile.am,
mpc8xx/vectors/Makefile.am, new_exception_processing/Makefile.am,
old_exception_processing/Makefile.am: Include compile.am
were needed to move exception processing to score/cpu.
significant things:
and PowerPC
same code base.
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
