Update #3285.
The BSP_output_char should output a char and not mingle with high level
processing, e.g. '\n' to '\r\n' translation. Move this translation to
rtems_putc(). Remove it from all the BSP_output_char implementations.
Close #3122.
Also use the const qualifier on the address pointer's target in in_*()
Closes #2128
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
* shared/console/uart.c: In IRQ driven mode also
keep reading chars while they are available (fifo
could be enabled).
* shared/console/console.c, shared/console/uart.c,
shared/console/uart.h: added support for task-driven
console.
* shared/console/uart.c: Fix typo and spacing.
* shared/console/uart.c: when draining UART during
initialization (wait for possible printk() activity
to finish) look at TEMT (fifo, holding-reg and shift-reg)
rather than THRE (fifo, holding-reg only). This resolved
some scrambled output issues for me.
Enhanced semantics: if BSP initializes BSPBaseBaud to a negative
value then the driver interprets the modulus as a speed value
and uses the current setting of the divisor to compute the
clock speed (BSPBaseBaud). This is useful if you have a board
that you know is initialized e.g., to 9600 but you
don't know the clock speed.
* shared/console/uart.c: removed #define UARTDEBUG
* mvme5500/irq/irq.h, psim/irq/irq.h, shared/console/uart.c,
shared/irq/irq.h: Renamed BSP_ISA_UART_COMx_IRQ -> BSP_UART_COMx_IRQ
(uart driver is ISA independent).
Removed ugly #ifdef mvme2100. Added test for
BSP_UART_USE_SHARED_IRQS symbol which a BSP can define to request
that the serial interrupt be shared.
PR 779/bsp
* clock/p_clock.c, console/console.c, console/uart.c, console/uart.h,
irq/irq.c, irq/irq.h, irq/irq_init.c:
powerpc: add parameter to new exception interrupt handlers
* Makefile.am, bootloader/misc.c, bootloader/pci.c, bootloader/pci.h,
console/console.c, console/inch.c, console/reboot.c, console/uart.c,
console/uart.h, irq/irq.c, irq/irq.h, irq/irq_init.c,
motorola/motorola.c, motorola/motorola.h, openpic/openpic.c,
openpic/openpic.h, pci/detect_raven_bridge.c, pci/pci.c,
start/start.S, startup/bspstart.c, vectors/vectors_init.c,
vme/vmeconfig.c: Add MVME2100 BSP and MPC8240 support. There was also
a significant amount of spelling and whitespace cleanup.
* tod/todcfg.c: New file.
PR 379/bsps
* console/polled_io.c: libcpu provides 'printk' already.
Therefore, the implementation in this file was removed (still
used for the bootloader, though). It now provides BSP_output_char()
for libcpu's printk().
* console/uart.c, console/uart.h: BSP_output_char_via_serial()
prototype changed to match the BSP_output_char_function_type. Note
that the motorola BSPs use polled-io for the output_char routine, not
the uart.c version. The latter can be used be other BSPs however
(e.g. SVGM).
* console/console.c, console/consoleIo.h, console/polled_io.c,
irq/irq_init.c, openpic/openpic.c, pci/detect_raven_bridge.c:
Unfortunately, the supported 'printk' format string subset of the
polled-io and libcpu implementations are different - hence, a few
format strings in the ppc/shared BSP were changed.
PR 349/bsps
* console/console.c, console/uart.c, console/uart.h: implement
IOCTLs for the serial (UART) console to install/retrieve a BREAK-IRQ
callback. The callback routine (if installed) is invoked from the
UART ISR when a BREAK interrupt is detected. This can be used
e.g. to enforce a "hotkey" reboot a la vxWorks Ctrl-X (although we
use the serial line break condition) NOTE: The callback runs in
ISR context.
* bootloader/misc.c, console/Makefile.am, console/console.c,
console/consoleIo.h, console/inch.c, console/polled_io.c,
console/uart.c, console/uart.h, include/bsp.h, irq/Makefile.am,
irq/irq.c, irq/irq.h, irq/irq_init.c, openpic/openpic.c,
openpic/openpic.h, pci/Makefile.am, pci/pci.c, pci/pci.h,
residual/Makefile.am, start/start.S, startup/bspstart.c,
vectors/vectors.S, vectors/vectors.h, vectors/vectors_init.c:
Per PR216, "libbsp/powerpc/shared" BSP has been modified considerably
with the goal to make it more flexible and reusable by other
BSPs. The main strategies were:
- eliminate hardcoded base addresses; devices use offsets
and a BSP defined base address.
- separate functionality into different files (e.g. reboot from
inch.c to reboot.c) which can be overridden by a 'derived' BSP.
- separate initialization code into separate files (e.g. PCI
bridge detection/initialization was separated from the more
generic PCI access routines), also to make it easier for
'derived' BSPs to substitute their own initialization code.
There are also a couple of enhancements and fixes:
- IRQ handling code now has a hook for attaching a VME bridge.
- OpenPIC is now explicitely initialized (polarities, senses).
Eliminated the implicit assumption on the presence of an ISA PIC.
- UART and console driver now supports more than 1 port. The current
maximum of 2 can easily be extended by enlarging a table (it
would even be easier if the ISR API was not broken by design).
- fixed polled_io.c so it correctly supports console on COM2
- fixed TLB invalidation code (start.S).
- exception handler prints a stack backtrace.
- added BSP_pciFindDevice() to scan the pci bus for a particular
vendor/device/instance.
As part of this effort, the mpc750 libcpu code is now shared with the
ppc6xx.
